Old 08-25-2020, 08:59 PM #1
pelantire pelantire is offline
pelantire is on a distinguished road
1988 3VZE TR4 fuel injector upgrade
So I ordered new Bosch 4-hole injectors from precisionautoinjectors.com but I realized they are the newer high impedance injectors. On my 88 3VZE they are definitely low impedance, checked it myself with a multimeter.
Question: Can I do the injector resistor box delete to run these new injectors? Will my ECU be ok?
From pirate4x4 I read this: "Toyota used the injector resistor box from 85 to 88 or 89 on the 22re. Its there because the low impedance injectors are only around 1-3 ohms and without the box it could fry a computer pretty fast. Sometime in 88 or 89 they quit using the resistor box and starter using different high impedance injectors around 11-13 ohms. You can use the resistor delete which is basically just splicing the three wires together but you also have to use high impedance injectors or it might fry the computer. Also don't use high impedance injectors with the box."
Any help appreciated
pelantire is offline   Reply With QuoteReply With Quote
Old 05-18-2021, 09:36 PM #2
Dom1988P/U Dom1988P/U is offline
Dom1988P/U is on a distinguished road
I have a set from precision auto injectors on the way and will be attempting to convert to high impedance as well. How did it go?
Dom1988P/U is offline   Reply With QuoteReply With Quote
box , high , impedance , injectors , resistor
3VZE 3.0L V6 4-hole upgrade fuel injectors. BS? airdreams1 Classic T4Rs 31 03-29-2019 12:34 AM
1988 3VZE won't start mechatater Classic T4Rs 1 03-27-2015 08:06 AM
Fuel injector upgrade queston. Need Help MATTMAKESBOOST Engines / Suspension / Wheels / Tires / Audio / Accessories 5 02-13-2010 07:07 PM
93 3vze v6 injector question invader Classic T4Rs 2 08-19-2009 10:24 AM
PG011R-05 06/09/2006 Fuel System - Fuel Injector Cleaning Procedure CBR_GUY_IA TSB 0 07-12-2009 09:44 PM
