Old 08-29-2020, 03:57 PM #1
asimelea asimelea is offline
asimelea is on a distinguished road
Power steering pump pulley nut
What is the best way to secure the pulley on a power steering pump from rotating to remove the securing nut? I've hit it with penetrating fluid and I have tried to remove it with belt tension on and while trying to hold the pulley by hand, but the nut is too tight. I've thought about locking onto it with vise grips but assume this would be a bad idea since it could deform the pulley. I'm not seeing any other way to secure the pulley so that I can crank on the nut. This guy gets it loosened no problem How to replace the power steering pump | 2nd gen Toyota 4Runner 3.0 3VZE - YouTube
asimelea is offline   Reply With QuoteReply With Quote
Old 08-30-2020, 10:04 AM #2
kc15842 kc15842 is offline
Real Name: Kevin
kc15842 will become famous soon enough
Real Name: Kevin
Are you using an impact gun? Sometimes the quick hammer of the impact will break a tough nut loose easier than a wrench or ratchet.
1987 22R-E, SR5. 5 Speed, 31's BFG A/T, stock wheels. 4.56 Gears, Rear Detroit locker Front True Track. 1.5" BJ Spacers & Extended Shackles in the rear.
1992 3.0, SR5. 5 Speed. 31's BFG M/T, stock wheels. 4.30 Gears-NON ADD- manual hubs, Elocker, 1.5" BJ Spacers, Moog springs w/ spacers. Sold
kc15842 is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 12:24 PM #3
Wish I had an impact gun. I only have hand tools. I wasn't able to get back to working on it over the weekend, but my next plan is to wrap rope around the pulley and double back on it to bind it up. I've sprayed it with penetrating oil so hopefully my next attempt is better.
Old 09-01-2020, 09:22 PM #4
Justthemechanic Justthemechanic is offline
Justthemechanic is on a distinguished road
I used a small pipe wrench on the back side of the pulley, where the pulley slides on the pump shaft. The wrench gripped the weld and held the pulley and I was able to removed the nut.
93 SR5, 3.0, 5 speed, OME 2” lift, BudBuilt skid plates and crossmember, Rocky Road Outfitters sliders, Spartan rear locker.
Justthemechanic is offline   Reply With QuoteReply With Quote
nut , power , pulley , remove , steering
Bolt came off Power Steering pump pulley he's gone 3rd gen T4Rs 1 10-03-2018 02:46 PM
Play in Power Steering Pump Pulley Mgyver1 3rd gen T4Rs 0 11-19-2014 09:50 PM
Which direction does the Power Steering Pump pulley turn on the 5VZFE (3.4)? xcmountain80 3rd gen T4Rs 2 08-18-2014 07:58 AM
Problems with new power steering pump/ new pump with fluid. no power steering? cdcrone123 Classic T4Rs 3 08-27-2013 09:29 PM
Servicing My Power Steering Pump Pulley Maritimer 3rd gen T4Rs 4 08-05-2012 08:57 AM
