Originally Posted by omgitskyleb
Got a chance to ply around with this a little more. I pulled the harness from the connector on the inside passenger kick panel. Traced it from connector all the way to inside the door and up to door locks. Harness is pristine all the way through.
Tried something on the pass door switch: i took a pair of needle nose pliers and jumped the “down” pins on the switch. No juice. I then held down on the connector and jumped the down pins and it works! Release the needle nose and the window won’t go down anymore.
Is this a grounding issue that I’m missing?
have you tried a new switch?
when you traced the harness did you unwrap it?
i thought mine was pristine too and found that after 25 years a couple of wires were crimped. sliced and soldered them back together.
