Old 09-28-2020, 10:01 AM #1
Kencart Kencart is offline
Kencart is on a distinguished road
Vacuum leak?
Hello,
I have a rather loud hissing (vacuum leak?) at idle that I cannot figure out on my 92 3.0 VZE. Almost sounds like it’s coming from the refrigerant lines but it occurs with the AC off (as well as on). It goes away at with the engine rev’d up but comes back instantly when returning to idle. None of the lines seem to be leaking. I thought maybe the pair valve but if I pull the lines off the VSV and put them together, manually engaging it, I hear the valve open and no change to the hiss.
Additionally, I have been having trouble setting my idle (but I’m assuming this supposed leak is the problem).
Any suggestions?
Thanks!
Kencart is offline   Reply With QuoteReply With Quote
Old 09-28-2020, 10:36 AM #2
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
spray a little starting fluid where the hiss is coming from, if it revs up, inspect that area more.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 09-28-2020, 11:09 AM #3
Tried that. No effect.
Old 09-28-2020, 05:09 PM #4
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Get a 3 foot length of garden hose or fuel hose and use it as a stethoscope - one end to your ear and the other probing various areas. You'll hear the leak loud and clear when you get close.
Be VERY careful around the fan belt while doing this!
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 10:40 AM #5
Well that was enlightening. I found air sucking in through the filter on the fuel pressure VSV. I looked at the diagram to make sure everything was hooked up right and apparently the PO Had put the egr and fp VSVs together backwards? The filter was where the vacuum line goes, vacuum line I think on the port that goes to the valve etc. I haven’t drawn it out, maybe it works the same way in that configuration but the filter is no longer sucking air.
That said, I still have a vacuum leak somewhere. Seems to be under the intake plenum. Injector? Plenum gasket? Anything else under there that could cause it? I notice adjusting the idle does increase/decrease the sound of the leak if that means anything.
Also, I noticed a broken bolt on the valve cover. I do hear the hiss slightly in that area but if I pull the hose from the other valve to the TB and plug the holes there is no change to the sound so that cannot be the issue correct?
Thanks!
Old 10-24-2020, 04:49 PM #6
4RunnerNorway 4RunnerNorway is offline
4RunnerNorway is on a distinguished road
I second this
4RunnerNorway is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 03:26 PM #7
4x4withcheese 4x4withcheese is offline
4x4withcheese is on a distinguished road
Hello, I’m having a similar issue with my 95 v6 4runner - I don’t think it’s a vacuum leak, I’m wondering if it could be the Idle Air Control valve. The engine idles at 1500-2000 RPMs most of the time lately, whereas it used to idle at 1100-1200. I replaced the spark plugs and wires and found leak spots in the air intake hose so replaced that as well. After those replacements it still idles high yet the RPMs lower to normal levels when I go to accelerate after idling, which makes me think it’s specific to the idle control. Has anyone experienced this before or have advice?
1995 4x4 4Runner Manual 3L V6
4x4withcheese is offline   Reply With QuoteReply With Quote
idle , leak , lines , vacuum , valve
Would this cause a vacuum leak? HappyHooligan 3rd gen T4Rs 11 08-31-2020 01:54 PM
Vacuum Leak mmendelscfi 3rd gen T4Rs 0 01-22-2017 04:45 PM
Possible Vacuum leak...idk? Blueaussie Classic T4Rs 6 07-10-2013 03:09 PM
Coolant leak, whining noise, vacuum leak, alternator, starter, battery issues Max O 3rd gen T4Rs 4 12-03-2009 10:31 AM
