Old 10-06-2020, 05:21 PM #1
chester4Run chester4Run is offline
chester4Run is on a distinguished road
2nd Gen Rear ABS Light
There's some misinformation on this issue around, and I finally figured it out, so I thought I'd post. Background: I've had the yellow Rear ABS dash light lit since my son did an emergency breaking maneuver as part of an accident he was involved in. I couldn't find a problem with the rear brakes nor the sensor in the differential. But I also couldn't seem to disable that light.
These posts helped me find the solution:
Can I disable/remove my 2nd gen rear ABS? | Pirate 4x4
ABS Removal
removing rear abs - YotaTech Forums
The solution is to unplug BOTH the ABS computer and the ABS relay.
The ABS computer is behind the glove compartment, up behind the horizontal metal bar. You'll need to remove two screws and a nut then pry/wiggle it downward, then you can unplug it. The plug release is on the top of the connector, which isn't accessible with it installed.
The ABS relay is fastened the passenger side of the engine compartment near the hood hinge with a single bolt. Unplug it.
I also removed the EFI fuse for a few minutes for good measure, but no ABS light on the dash now (doesn't even test light when the key is turned). I removed both components and electrical taped the plugs.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
chester4Run is offline   Reply With QuoteReply With Quote
Old 11-23-2020, 11:36 AM #2
nicakasper nicakasper is offline
nicakasper is on a distinguished road
I have a 1993 4runner 2wd, I recently unplugged my ABS computer and relay, plus I disconnected the rear speed sensor and the ABS modulator. The ABS light does not turn on and the car is braking well. However, my radio doesn't turn on anymore. I wonder if it's related to me disconnecting the battery, all the fuses look normal.
nicakasper is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 06:29 PM #3
I haven’t had any radio issues since this change. Have you checked your fuses?
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
Old 12-14-2020, 08:35 PM #4
Not sure what was the issue with the aftermarket radio. But I ended up connecting and disconnecting the factory AND now the aftermarket radio works. As far as the ABS, I need to figure out how to remove the ABS actuator/modulator (?) since it continues to leak powersteering fluid. Gonna look for a non-ABS truck at the junkyard and replace the hoses.
abs , find , light , rear , unplug
Rear luggage light and door adjar light go on when offroading on washboard roads randy88fj62 4th Gen T4Rs 1 11-18-2019 09:27 PM
2012 SR5 rear bumper question - Custom Rear Fog Light (for EU) RysiuM 5th gen T4Rs 22 04-09-2018 06:29 PM
4LO light comes on randomly in 2H, rear wiper weird, rear window sticks! Summit Problems & Warranty Issues 5 11-29-2012 07:48 PM
Rear wiper/rear defroster/dome light not working... fuses? BBV 4th Gen T4Rs 5 03-12-2011 02:55 PM
Display Light and Rear Brake Light WellingtonB 4th Gen T4Rs 24 02-22-2011 04:26 PM
