okay, so as other posts have pointed out, to get the sunroof off, in "tilt" mode you squeeze the two silver arms together until they clear their pivot pins, then tilt the glass up further and it slides out towards the rear.
the four drains all passed water just fine. i cleared them with compressed air just for good measure. They drain out of the seam weld at the bottom of the body on each side where there are little pinched areas where they are meant to drain, about 5 on each side.
now i guess i'll remove the front cowl and see if the fresh air intake is leaking or something?
