Old 11-09-2020, 06:46 AM #1
4RunnerNorway 4RunnerNorway is offline
4RunnerNorway is on a distinguished road
Tail Light/Dash Short
Its looks like I have a short in my tail lights or dash as the fuse keeps blowing.
All bulbs works. Problem occured after tailgate repair. Have reversed everything I did and still fuse keeps blowing.
If I install a new fuse, it blows 5sec after turning the lights on. Not at once, but 4-5 seconds.
Im kinda new at this, so any help is greatly appreciated? Where do I start?
I have checked tail lights, trailer connector... Looks fine to me but then again, I rly have no idea..
4RunnerNorway is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 04:18 AM #2
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Thoroughly inspect all wires that have beem touched during last repair for worn out / torn insulation such that copper in wire touch metal body. Check if there are trailer wiring harness. Those are usually poorly-installed and have been proven problematic.
If your senses of touch, sight, feel do not sense anything out of the ordinary. Need a voltmeter.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 12:53 AM #3
WPG93's Avatar
WPG93 WPG93 is offline
Real Name: Paul
WPG93 is on a distinguished road
WPG93's Avatar
Real Name: Paul
Hey there, I had it and messed with the wires in my tailgate and it stopped, not sure of I fixed anything though. After what Rad suggested I'd suggest thoroughly looking at the wires around where the tailgate hinges. It probably just takes 4-5 seconds to heat the fuse enough to blow.
Another thing you can do, is unplug the tailgate harness completely and see if it still burns out, if it doesn't then it ain't your tailgate, and if it does you've at least ruled out any secondary problem tricking you.
Let us know how it goes!
WPG93 is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 08:52 AM #4
Unplugged complete harness that goes to the tail. Still the fuse blows. Its probably something within the dash... Relay most likely
Old 11-20-2020, 11:35 PM #5
WPG93's Avatar
Real Name: Paul
WPG93's Avatar
Real Name: Paul
Can you have the truck on for a while with the fuse in and the lights off without blowing the fuse?
If it is absolutely only when you turn the lights on I'd have a very very good look at the wires from the trailer connector as that's probably the main culprit. Trace them as far as you can and look for any damages or exposed wires. If you have a multimeter or can borrow one check for ohms between the frame and each pin in the trailer connector.
I'm sure others may have more experience and information on this but I like to rule out other things before I start thinking it's in my dash.
Old 11-23-2020, 03:34 PM #6
The fuse blow after turning the light control on the steering wheel to TAIL. Then you hear the light reminder buzzer and the fuse blow 4 sec after.
My circuit is different from american ones as there other electrical standards here in Norway. My dash/panel lights are connected to TAIL circuit, aswell as my parking lights
Old 11-23-2020, 03:48 PM #7
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by 4RunnerNorway View Post
...My dash/panel lights are connected to TAIL circuit, aswell as my parking lights
That is the standard item list on that circuit in USA too, perhaps worldwide since Runners are only made in one place, Japan.
Start using a volt meter to detect which wire has a draw when everything is Off. Luck.
Old 11-24-2020, 10:14 PM #8
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
seems like the harness would be very similar since all of these things were built in japan. Only differences would be left/right hand drive.
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
blowing , fuse , lights , short , tail
Diagnosing a dash short mendozer Engines / Suspension / Wheels / Tires / Audio / Accessories 7 01-29-2020 02:17 AM
2001 4RL -- lost tail lights and dash panel light True Colors 3rd gen T4Rs 51 05-24-2018 12:13 AM
Check engine light, vsc light, traction light all on after a short circuit mikeng 4th Gen T4Rs 3 01-01-2018 07:54 PM
Clear Tail Lights, Tail Light Guards, & Many Bulbs For Sale! Fo_SheeZy 3rd gen T4Rs 21 09-11-2011 04:35 PM
00 4Runner LCD light short 004 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 01-25-2006 01:15 PM
