Old 02-07-2021, 05:41 PM #1
_ExpeditionMan _ExpeditionMan is offline
_ExpeditionMan is on a distinguished road
Help Needed! Passenger Power Mirror Stopped Working - Troubleshooting Details
All,
Recently the passenger power mirror on my '94 has stopped working. Breaking into the FSM I performed a few tests in an attempt to resolve the issue.
1) Remove mirror switch and test per FSM. Result: PASS
2) Remove mirror assembly and apply voltage directly to connector for mirror motor on bench. Check mirror moves in all directions. Result: PASS
These two tests lead me to believe I have an issue with the wiring on the harness side. I confirmed this by checking for voltage and continuity at the harness side of the passenger door connector while having a helper engage the switch. Got nothing.
Next, I rigged up the passenger mirror so that two of three pins were connected to the harness, leaving only the solid green (harness side) to black (mirror side) pin disconnected. I then ran a new wire to the mirror black wire from a bolt on the door grounding it locally. Using this arrangement I was able to move the passenger mirror using the switch but ONLY in the up and left directions.
This is where I left off and could use some help. It seems clear to me I have an issue with the grounding wire on the harness side of the passenger connector. The inability to turn right or down when grounded locally means the polarity is not being switched.
This recently became an issue after completing a head gasket job, so is there a ground I could have missed?
Any thoughts or assistance?
1994 Toyota 4Runner SR5 - 3.0 V6 5spd 4WD
_ExpeditionMan is offline   Reply With QuoteReply With Quote
harness , issue , mirror , passenger , side
Turn signals stopped working, hazards still work fine - need troubleshooting help sierraskier 3rd gen T4Rs 19 06-10-2023 09:31 PM
Rear and passenger windows just stopped working... JustSomeName 4th Gen T4Rs 7 01-17-2022 01:19 PM
Auto-dimming mirror stopped working, suggestions? scott78945 4th Gen T4Rs 13 10-12-2009 09:37 PM
1992 passenger window stopped working duner Problems & Warranty Issues 1 07-06-2005 02:00 PM
