Originally Posted by swerks
Can anyone tell me how to go about rear heat delete ? which hoses can I remove or bypass
There will be 2 lines, a send and a return, that run from your firewall under your 4runner to a small oval shaped hole up into your rear heater. You can cut these there and drain the coolant into something, then go back to your firewall and route the 2 hoses into each other using the T nipple already there. Then remove the heater from the inside of your runner.
