Old 03-07-2021, 09:12 PM #1
Gatchaman Gatchaman is offline
Gatchaman is on a distinguished road
2nd Gen 4Runner sway bar bushing replacement question - torque specs?
My OEM (1995 4runner 4wd) sway bar bushings are pretty well worn out, so I'm replacing them with some Energy Suspension bushings.
I've been searching for info on the various bolt/nut torque specs for specifically the front and rear sway bars. My Haynes book doesn't have them, searching the internet just returns all kinds of answers. Anyone know what they are or should I just do the old fashioned... tight then 1/4 turn?
Gatchaman is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 01:47 AM #2
4RunnerSafari's Avatar
4RunnerSafari 4RunnerSafari is offline
4RunnerSafari will become famous soon enough 4RunnerSafari will become famous soon enough
Here you go, use the numbers all the way to the Left as NM specs.
4RunnerSafari is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 02:41 AM #3
Thank you! For the spec diagram. My book didn’t have the specs. I would have replied sooner but I was out camping with my other Toyota!
Old 03-17-2021, 05:19 PM #4
No problem, let me know if anything else you need.
Sent fra min WAS-LX1 via Tapatalk
Old 03-20-2021, 08:52 PM #5
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
The FSM numbers are best, if you can find them. Otherwise, often a Haynes manual will have a table somewhere in the front pages of the book of typical torques for various bolt sizes. For non critical stuff like sway bar bushings, such a table is completely adequate, because it's very likely a similar table is what the engineers used in the first place. Typical torques for various bolt sizes are well known in the industry. Critical stuff like head bolts, suspension bolts, drive shaft bolts get special attention, but otherwise they use standard torques for most stuff.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
4runner , bar , specs , sway , torque
Steering Rack and Front Sway Bar Bushing Replacement mtbtim 3rd gen T4Rs 120 12-14-2023 11:12 AM
Worst luck ever during sway bar bushing replacement Rocky5000100 3rd gen T4Rs 45 08-21-2018 04:17 PM
Help: UCA, Sway bar and other torque specs G8RB8_12SR5 5th gen T4Rs 2 08-28-2014 10:36 PM
Sway bar bushing and bumpstop replacement durrell 3rd gen T4Rs 16 02-16-2011 11:04 PM
Steering rack bushing torque specs? 1985taylor1925 3rd gen T4Rs 9 09-29-2010 02:44 AM
