Old 05-27-2021, 05:39 PM #1
maxmad88 maxmad88 is offline
Real Name: brian fischer
maxmad88 is on a distinguished road
88 4runner charging issue
Ok so i need some help i have an 88 4runner that wont charge even though it says its charging.. i can fully charge the battery on a battery charger and it will start and run fine put my multi meter on it says its charging. But it still sputters and dies than it acts like the battery is dead says its fully charged but when it cranks drops to like 6-8 volts. Battery is new and has been tested as good. I cleaned up the grounds and change both battery terminals. The alternator is also new. Any help is appreciated.
maxmad88 is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 01:17 AM #2
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Originally Posted by maxmad88 View Post
... it says its charging.. ... put my multi meter on it says its charging. ... says its fully charged
A well-stated problem is almost solved. How do you know that the battery says it is fully charged?
Do voltage checks described in this post, then tell us what is different on your truck. (How Charging System Works - 22RE - YotaTech Forums)
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
4runner , battery , charge , charging , fully
Charging issue Flighht2k Lexus GX470/460 3 05-29-2019 09:20 PM
88 4Runner charging issue Jordan Petry Classic T4Rs 4 08-12-2014 01:09 AM
charging issue gsalazar 3rd gen T4Rs 0 03-11-2013 09:59 PM
charging issue chris001979 Classic T4Rs 5 02-21-2013 01:30 PM
charging issue k_schutte Classic T4Rs 7 12-27-2010 10:42 AM
