Old 07-11-2021, 11:49 PM #1
Soulprogression108's Avatar
Soulprogression108 Soulprogression108 is offline
Soulprogression108 is on a distinguished road
2nd gen runner brake bleeding walkthrough?
Has anyone found a good walkthrough for bleeding the brakes on our 2nd gen T4rís?
Iím about to do the rear bearings and axle seals and it requires pulling the rear lines off the wheel cylinders.
I just want to make sure I do it right. Iím not clear if I need to bleed all four brakes? It also sounds like thereís maybe a 5th place to bleed on the brake lines above the rear differential.
Thereís a lot of good videos and Iíve got some good tips on general guidelines for bleeding brakes, but neither the downloadable FSM or the Haynes manual gives anymore description than to start from the longest line from the master cylinder and work your way to the shortest.
Excluding the bleeder that maybe above the rear differential that would go.
Rear Passenger
Rear Driver
Front Passenger
Front Driver
Iíd love to skip doing the front if I donít need to. It had a brake job a couple years back before I got it so I dunno if it really needs a full flush and that means I donít have to take the front wheels off. That being said if the correct way to do it is to do all four brakes then thatís what Iíll do.
Iím going to do it manually with a little bottle rig up I made. 3/16 clear tubing. Through a drilled out hole in top of small gatorade bottle. Tubing is zip tied under the cap so it canít pull out and so I can hang the bottle if needed. Thereís also a small air hole to allow release of pressure build up.
If I have a hand Iíll have them do the pedal for me. If not Iíll do it myself.
Hoping thereís a good walkthrough or video out there somewhere that shows our trucks specifically ;)
Thanks in advance!
Bearings should be here tomorrow!
Whoohoo! No more clunkity clunk and no more mess all over my wheel!
White Lightning Surf Explorer
1994 T4R 22re 4x4
Stock except for
Aluminum 15Ēs and 31x10.5 ATs
Soulprogression108 is offline   Reply With QuoteReply With Quote
Old 07-12-2021, 02:47 PM #2
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone has a spectacular aura about Dropzone has a spectacular aura about Dropzone has a spectacular aura about
Dropzone's Avatar
don't forget to bleed the LSPV
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 07-13-2021, 03:29 PM #3
Care and Bleeding of Your Brake System
Found this page while searching the link to rear wheel bearing replacement one member sent me on my other post ;)
1994 T4R 22re 4x4
Stock except for
Old 07-14-2021, 10:31 AM #4
4RunnerSafari's Avatar
4RunnerSafari 4RunnerSafari is offline
4RunnerSafari will become famous soon enough 4RunnerSafari will become famous soon enough
Bleed from farest away from the brakebooseter im enginebay. Example. RL- RR - then the LSPV- RF - LF. I did this some times, and brakes are good now. Make sure to bleed the LSPV good as well. check if the piston is not stuck also. You can manualy check this to screw off the 2 M8 bolts on the bracket on the panhard bar. and push it up and down manually.
i did this as well,. i strugle with some leakage on the nipple at first so i bleed all the 4 wheels several times. it pass the brake test with good result today as well.
Good luck.
Sent fra min WAS-LX1 via Tapatalk
4RunnerSafari is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 06:53 PM #5
So everything went well, I followed the guide in the link I posted above and started Driver Rear, Passenger Rear, LSPV, Passenger Front, Driver Front, and everything ran clear. I can tell you it was about as funky as brake fluid can get, Kauai red dirt or rust hard to tell, but chunky and funky. Cleared out the lines and topped up with fresh Dot3
I used the one person method with bleed bottle made from a medium sized water bottle. One hole in cap to fit snug clear tubing in 3/16 i.d. and one small hole for venting in the cap. A zip tie on the inside of the cap holds the tubing from pulling out.
Old fittings can leak a little air around the threads so it's good to either pack around with some grease or just barely crack them.
Glad it's another couple years before need to do again!
1994 T4R 22re 4x4
Stock except for
brakes , front , good , rear , thereís
Rear brake lines exploded while bleeding brake fluid benztech82 4th Gen T4Rs 3 08-11-2017 08:16 PM
Brake bleeding after tundra brake upgrade Cadaverous 3rd gen T4Rs 25 08-11-2017 12:02 AM
Brake Bleeding ... seems different Bumbo 4th Gen T4Rs 15 02-18-2017 10:36 AM
Brake bleeding Riv 67 4th Gen T4Rs 2 03-21-2015 04:28 PM
Brake Fluid - Brake Bleeding RiFF RaFF Classic T4Rs 5 11-15-2013 09:23 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
