Old 08-13-2021, 07:58 PM #1
Lil Red Yarder's Avatar
Lil Red Yarder Lil Red Yarder is offline
Lil Red Yarder is on a distinguished road
Bad day
Today I had to replace the valve cover gaskets on my 88 with the 3vze. Did an egr delete while I was at it and got rid of the California emissions. Now it won't start. I did get it to start once but ran like crap. I'm fairly new to these engines besides basic maintenance. I normally run 22re. I replaced the circuit open relay but no luck there. I'm completely lost at this point. Yes I did look to see if anyone else has had this problem. Please someone help. I'm completely lost at this point
Lil Red Yarder is offline   Reply With QuoteReply With Quote
Old 08-13-2021, 08:23 PM #2
wallytoo's Avatar
wallytoo wallytoo is offline
wallytoo has a spectacular aura about wallytoo has a spectacular aura about
wallytoo's Avatar
in putting it back together, you either didn't connect/plug something in, or you've mixed some connections up. only you will be able to determine that, as "we" aren't there to look at or see your truck.
alternatively, in your attempt to remove the emissions equipment, you have also either left something unplugged/open, or routed hoses incorrectly, etc. same issue; only you are there to see the truck, you'll need to figure it out.
member, new hampshire timberland owners association (NHTOA)
1987 4runner sr5, 22re, 5-speed
1988 4runner sr5, 3.0, auto (parts rig)
1987 4runner, sr5, 22re, 5-speed (#2)
wallytoo is offline   Reply With QuoteReply With Quote
Old 08-14-2021, 12:34 PM #3
Took the plenum back off and check everything. All vacuum is routed correctly. All electrical I connected. Had a rip in the gasket. Replaced it. Still got nothing. Starting to wonder about fuel pressure regulator. Gets fuel but doesn't hold pressure. Gonna check for any leaks in the lines shortly
completely , lost , open , point , start
