Old 08-17-2021, 11:19 AM #1
Dannyw Dannyw is offline
Dannyw is on a distinguished road
1990 4Runner SR5 3.0 Help
I got my daughter this 1990 3.0 4runner. Its in great shape, No hail and just a tiny bit of rust above the rear wheel. I had to replace the alternator which was super easy. But the Speedometer and odometer dont work everything else does RPMS etc. I order the cable but I was also told i need A speed sensor Part 8941135010. I was just looking for insight on the problem.
1990 4Runner SR5 3.0 Help-65032882687__253ca110-0776-4af8-a5ff-e43351131dca-jpg
Dannyw is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 11:13 AM #2
3VZE93's Avatar
3VZE93 3VZE93 is offline
3VZE93 is on a distinguished road
3VZE93's Avatar
I would say you're on track seeing as other portions of the gauge cluster are functioning. I believe that's the sensor that plugs into the transmission housing, easy replacement. Keep us posted.
3VZE93 is offline   Reply With QuoteReply With Quote
Old 09-08-2021, 10:49 AM #3
I ended up trying the sensor first with no change. So I dove into the speedo cable which was alot easier than expecting. I got it in and everything is working now, other than the A/c which needs a new compressor. I did get a new bumper and lower valance, Which she want to rhino line black. The grill needs to be replaced at some point it brokes and rattles. I did order a used switch for the sunroof, the original was broke but it seems the motor is also bad. But it is coming along.
1990 4Runner SR5 3.0 Help-img_1970-jpg
Old 09-09-2021, 09:43 PM #4
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
Nice looking ride! They don't salt roads in Kansas? Keep up on your valve clearances, esp #6 and it'll last you a long time. Actually it'll last either way, just won't be much fun to drive with burnt valves. Usually when you start seeing rust above the rear wheel there is significantly more rust hiding behind the rear bumper, so might want to pull that off and repair or at least spray some bar and chain oil in there when you have time, but that is much better shape than we see in the northeast. For your AC, you might know already, but they used R12 until '94 so you'll want to evac the system well and get all that oil out, fortunately for parts the pumps are interchangeable with the R134a units from the 3rd gen 4Runners (just need to swap the pulley), and the '94/95 2nd gens. Replace the dessicant dryer while you're in there too.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 09-14-2021, 04:46 PM #5
Well she told me the cruise control went out again, speedo and that are all still working. I checked the fuses, I hate to think that speed sensor went out already. guess its time to start checking stuff again
Old 09-14-2021, 11:12 PM #6
jbtvt's Avatar
jbtvt's Avatar
I've never had a 2nd gen with working cruise control, the vacuum actuated system seems to be pretty unreliable as it ages. Will be swapping the 3rd gen cruise setup into my '90 one of these years but that already has a 3.4. Good luck
4runner , odometer , rpms , speedometer , work
1990 4runner Mr M Classic T4Rs 0 10-21-2013 04:32 PM
1990 4runner Screw lose Classic T4Rs 3 07-24-2013 05:48 PM
1990 4runner shaun_w83 Classic T4Rs 1 07-13-2007 11:14 AM
WTB: 3.0 6 cyl for 1990 4runner loyolacub68 Want to Buy/Trade 0 02-13-2007 11:30 PM
F/S: 1990 4Runner SR5 V6 Hazade Classifieds - buy & sell (no commercial ads please) 3 12-10-2004 03:49 PM
