Old 08-17-2007, 12:02 PM #1
Deranged Deranged is offline
Deranged is an unknown quantity at this point
Pinion Bearing
My rear differential code is G254 which is an 8" 4.56 4 pinion. I have looked at multiple sites looking for a new bearing and every site I have looked at only has a 7.8" bearing. Is this something I can buy only from a dealership or is it the same size bearing? Any ideas?
Deranged is offline   Reply With QuoteReply With Quote
Old 08-19-2007, 12:27 AM #2
ovrrdrive's Avatar
ovrrdrive ovrrdrive is offline
ovrrdrive is on a distinguished road
ovrrdrive's Avatar
Honestly, this isn't something you can change yourself unless you have the tools and know-how to do it. And if you get a rebuild kit and pay to have it installed you'll spend more than you would to just get another 3rd member from a junkyard and install it yourself...
2003 Silver/Gray SE5 V8 T4R
1995 4x4 Xcab Truck 8.5" lift, 36x13.5 Iroks on M/T Classic Locks, 5.29's, Lockright locker, OBA and a Train Horn
ovrrdrive is offline   Reply With QuoteReply With Quote
Old 08-28-2007, 01:13 PM #3
Thanks for the info. After heeding your advice I searched around for instructions on changing it out. I found this site which was really detailed on how to do it and it was a little more work than I wanted to do.
http://www.4x4wire.com/toyota/tech/gear_setup/
I just took an identical 3rd member out of a parts truck and had it swapped in about 2 hours. It drives like new.
Thanks again.
Old 02-11-2011, 10:16 PM #4
jsulen jsulen is offline
jsulen is on a distinguished road
I didn't know that this would cost you much if you replace your pinion bearing slinger. Thanks for the info 'ovrrdrive' .. I also notice that an 8" pinion is hard to find..
jsulen is offline   Reply With QuoteReply With Quote
Old 02-11-2011, 11:59 PM #5
s2kpuddydad's Avatar
s2kpuddydad s2kpuddydad is offline
s2kpuddydad is on a distinguished road
I'm sure you can get the bearings at a local Napa or other auto parts store. You did do it the easy way by just swapping out the third member. I build performance rears so I know that it is not a job for the inexperienced.
I am the PuddyDad, Creator of things for the S2000, Part provider to 4 Maltese dogs we lovingly refer to as Puddys. Puddy is a mix of two words, puppy and buddy. Small dogs like Maltese are little like a puppy and all dogs are your best buddy. Put the two together and you have a Puddy.
Rest in peace Cosmo The Wonder Puddy, we love and miss you very much
http://www.s2ki.com/forums/index.php...owtopic=825385
s2kpuddydad is offline   Reply With QuoteReply With Quote
Need a new engine fan bracket bearing, bearing or whole bracket? Jon 3rd gen T4Rs 36 03-25-2019 01:22 PM
Front Wheel Bearing Replacement gstai 3rd gen T4Rs 8 11-18-2012 04:34 AM
Worn Pinion Bearing at just 131K spo0587 4th Gen T4Rs 5 01-24-2010 10:01 AM
Replacing rear bearing gapboi210 3rd gen T4Rs 4 10-15-2006 05:02 PM
pinion bearing blow out hydro Classic T4Rs 8 10-27-2005 08:30 AM
