Old 09-22-2017, 02:03 AM #1
1990silverbullet 1990silverbullet is offline
Real Name: Rylee
1990silverbullet is on a distinguished road
Real Name: Rylee
1990 silver bullet runner
So i have been reading aroung and decide to get my first runner. I purchased a 1990 silver 3.sl0w. I found it 30 min after he put it on criags list and called right away. I looked at it after work and fell in love. I had been saving for a while so i bought her up. I am the 4th owner. Shes rust free and her frame is in great condition. I picked her up for a little pricey 3700. The only thing that is wrong is the the check engine light is on and the 4wd light is on even in 2wd. The engine is throwing a code 52 so im going to replace sensor and harness. as for the 4wd light idk. I almost forgot but I bought it with a borla race exhaust and its loud.I picked her up with 178630 miles.Everything other than that works perfect even cigarette lighter.I have had it for about a month and a half and i love it!!!!! so far i haven't done anything serious but i plan to in the future. Yesterday i bought another runner. shes gold and doesnt run. The gold runner has factory rear tire swing and Toyota original front bumper. I got her for 300$ I will be putting all the parts on my silver runner. also the interior is pretty damn good.
So far these are the parts I have put in the truck.
Fluids:
power steering
brake
clutch
front and back diff
tranny fluid
and radiator flush.
Parts
all belts
Spectrum radiator
o2 sensor
cold air intake
driver side and passenger cv
front and back brakes
front rotors
Thermostat.
power steering pump
wheel bearings
fixed exhaust leak
Knock sensor
o2 sensor(again)
Bilstein struts(front)
4wd t case switch(Didn't fix anything XD)
Shifter seat & cap
E-Brake cable(Broke but easy replacement)
Body Work:
I patched up the rust from under the bumper but pretty much the same time period I backed into a small tree on trail and a concrete pole so the rust is gone but the dents are not
1990 silver bullet runner-p1060699-jpg  1990 silver bullet runner-p1060656-jpg  1990 silver bullet runner-p1060529-jpg  1990 silver bullet runner-p1060402-jpg
1990silverbullet is offline   Reply With QuoteReply With Quote
Old 09-22-2017, 02:07 AM #2
Real Name: Rylee
Real Name: Rylee
So I bought a junked gold runner and it has a rear tube bumber so i will take off my rear bumper tonight
1990 silver bullet runner-gold-runner-jpg
Old 09-27-2017, 05:51 PM #3
Real Name: Rylee
Real Name: Rylee
So my once rust free runner is no longer rust free. I took off the bumper and there is a little bit of rust where the bumpers covering. The gold runner has rust free panels so I will have to cut them off it and put them on the silver runner. I don't know how to do body work but I will learn as I go. Have to wait till next paycheck to get everything I need.
1990 silver bullet runner-wrecked-qp-2-jpg  1990 silver bullet runner-drivers-side-jpg  1990 silver bullet runner-passenger-side-jpg  1990 silver bullet runner-wrecked-qp-jpg
1990 grey runner. 3.0 with a 5 spd (180100 miles)
1991 gold runner 3.0 with auto.(doesn't run but will soon(228,000))
Old 10-10-2017, 06:22 PM #4
ether_joe ether_joe is offline
ether_joe is on a distinguished road
Nice truck! What a steal!
ether_joe is offline   Reply With QuoteReply With Quote
Old 10-11-2017, 04:25 PM #5
Real Name: Rylee
Real Name: Rylee
Thank you!! Does any of you know if a ps pump from a 1991 3.0 will fit in my 1990 3.0. I have a 1991 as a donor car. would it be a direct fit?
Old 11-08-2017, 02:48 AM #6
Road4Running's Avatar
Road4Running Road4Running is offline
Road4Running is on a distinguished road
If they're the same engine then yes. FYI, be careful when removing the return hose, they like to disintegrate.
There should be a two wire switch on the front differential, it's right next to the actuator. I would start there. Another possibility is that the actuator for the front diff is stuck on. let me know what you find, I have both volumes of the factory service from toyota, complete with all wiring diagrams.
Road4Running is offline   Reply With QuoteReply With Quote
Old 01-23-2018, 07:17 PM #7
Real Name: Rylee
Real Name: Rylee
What should I do about the rust??I don't think im going to take it off the gold runner, because I think im going to fix it up. I was thinking about just cutting it out and welding a piece of sheet metal over it.The bumper would cover it up anyways.Has anyone done that before? also I got a little crazy when crawling and slid into a rock therefore breaking my light and denting up my rear qp. #Shouldofhadoffraodtires
Old 01-23-2018, 09:04 PM #8
128keaton's Avatar
128keaton 128keaton is offline
Real Name: Keaton
128keaton is on a distinguished road
128keaton's Avatar
Real Name: Keaton
I'd kill the rust and maybe weld a panel there. Cover it in some bedliner spray and you should be fine.
[DD]2003 Lexus LX470 - Black Onyx - Stock
[SOLD]2000 Toyota 4Runner - SR5 - White - 5-Speed - Toyota E-Locker (4.10s )- 620LB Eibach/OME 890 - 33" Falken Wildpeak ATs - 4x4 - 164k and climbing
[RIP] 1993 Toyota 4Runner - SR5 Sport - Black Onyx - 5 Speed - 31" Bridgestone Dueler ATs - 4x4 - Cracked Block at 254976 RIP
128keaton is offline   Reply With QuoteReply With Quote
Old 01-24-2018, 12:43 PM #9
Real Name: Rylee
Real Name: Rylee
As for the dent, do you think it would be easy to unbend or should I take it to a body shop?
Old 01-24-2018, 04:29 PM #10
128keaton's Avatar
Real Name: Keaton
128keaton's Avatar
Real Name: Keaton
I mean depends on how much you know and how much you wanna do. That dent is pretty creased. The bumper would cover most of it. At the very least, I'd just scuff the paint and spray bed liner on to prevent rust. Unless you are running tube bumpers, that should mostly be covered.
I whacked above the taillight real bad and I wish I knew how to cut/weld a panel out because thats what I should've done.
IMG_1173 by keaton.burleson, on Flickr
Still doesn't really look 'right'
Old 01-24-2018, 06:05 PM #11
Real Name: Rylee
Real Name: Rylee
Honest I think im going to try to pull it out. It wont look good but at least it wont be dented inward. At least your panel isn't dented anymore. I don't think it looks to bad. Its actually pretty good.
Old 01-24-2018, 06:35 PM #12
128keaton's Avatar
Real Name: Keaton
128keaton's Avatar
Real Name: Keaton
Its not great and needs to be repainted the RIGHT way (waiting for the summer).
This guy did a great job
https://www.yotatech.com/forums/f116...runner-208824/
Old 01-25-2018, 12:07 AM #13
giro's Avatar
giro giro is offline
giro is on a distinguished road
giro's Avatar
How long did it take to replace the CV joints? Both of my outer boots recently cracked and are leaking, but there's no damage yet. I'm thinking of just putting on new "weld together" boots off of rock auto for $21 each. I'm at 176k.
When you replaced the O2 sensor, did it change things much? On other cars (long ago, but similar years) I have had the check engine light come on when it needed replacement. With the mileage I think I probably should replace it, but I have enough other things on my list right now that the "if it ain't broke, don't fix it" thing runs through my head.
92 4runner SR5 Garnet Pearl (3K3), 5spd 4x4 V6 185k
22 Sienna AWD 9k
06 Sienna AWD 185k
98 4runner SR5 4x4 V6 auto 136k locking rear diff -- SOLD (and heard it's been totaled)
giro is offline   Reply With QuoteReply With Quote
Old 01-25-2018, 01:00 PM #14
Real Name: Rylee
Real Name: Rylee
Honestly the only reason I Bought brand new CV's was so I would have an extra pair. I took the old ones and rebuilt them and now they are good as new, and I have an extra pair for the trail. As for how long it took, it took about an hour a piece. Its honestly pretty easy if you do it the right way.
When ever I replaced the O2 sensor I didn't really notice a difference. Probably because my knock sensor is bad and my timing is retarded(Due to safe Mode) but im betting youll get better MPG though. Im not sure If it will give a code honestly. Mine was all rusted and looked like sh*** so I just replaced it. Mine probably wasn't broken but that's alright.
Old 01-26-2018, 02:12 PM #15
Real Name: Rylee
Real Name: Rylee
I picked up the sheet metal today. I will work on it when I get off. By the end of the weekend I will have a rust free runner. and maybe a rear tire swing
My 1990 4 Runner Gatti Classic T4Rs 31 02-21-2016 10:51 PM
1990 Runner 01yz426 Classic T4Rs 0 08-12-2014 12:09 AM
AFE Silver bullet installed. Aquabear 4th Gen T4Rs 11 07-04-2011 05:06 PM
FS: 1990 4 Runner SR5 V6 formulaz Classifieds - buy & sell (no commercial ads please) 0 06-09-2006 06:49 PM
1990 4 Runner ChicagoD Classifieds - buy & sell (no commercial ads please) 1 07-19-2005 08:13 PM
