Old 11-01-2021, 03:30 PM #1
sdb999 sdb999 is offline
sdb999 is on a distinguished road
Temperature Gauge Sender Type
1987, 5spd, SR%
I'm looking at a temp gauge that might be compatible with the OEM gauge sender unit. Does anyone know what Type of sender Toyota uses in these trucks?
Choices are
Temperature Sensor Type: K, E, S, R, J, T, B, WRe3-WRe25, Pt100, Cu50
Would like to keep OEM sender unit and drive this gauge.
Round Automobile Multimeter, 2 1/16'' (52 mm) [SYL-1813-MR] - $69.50 : Auber Instruments, Inc., Temperature control solutions for home and industry
Thanks, Steve.
sdb999 is offline   Reply With QuoteReply With Quote
Old 11-02-2021, 09:07 AM #2
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
There are two kinds of senders. One is just for the dummy light, and other are for gauge clusters with the temp gauge.
Thats all I know about them.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 11-02-2021, 02:05 PM #3
Bikeric's Avatar
Bikeric Bikeric is offline
Real Name: Eric
Bikeric will become famous soon enough Bikeric will become famous soon enough
Bikeric's Avatar
Real Name: Eric
I just bought a temp sending unit yesterday. Not sure if type J or K. The website info doesn't say either, but this is what you need.
Toyota 1984-1988 Engine Coolant Temperature Sensor 7.3211
1984 SR5, 1989 DLX, 2011 SR5 4wd
Bikeric is offline   Reply With QuoteReply With Quote
Old 12-15-2021, 12:32 PM #4
I ended up going with a mechanical temp gauge, works great in the factory location behind the thermostat. I was able to easily feed the sender lead into the cab of the truck via the hvac drain tube. This large grommet is on the firewall on the passenger side. Both the drain tube and grommet are soft rubber so the sender lead slipped in right next to the drain tube. No holes drilled, No rubber cut, and very tight seal.
gauge , sender , temperature , type , unit
88 aftermarket fuel gauge sender? SAC Classic T4Rs 5 02-05-2019 10:54 AM
2005 4x2 sr5 4.0 temperature gauge/fuel gauge Josh05 4th Gen T4Rs 0 09-10-2013 04:39 AM
Temperature gauge help!!! bertsch911 Classic T4Rs 8 02-28-2013 01:06 PM
Gauge pods, temp sender, etc? Mulepick Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-23-2005 11:10 PM
outside temperature gauge Schnauzer 4th Gen T4Rs 5 09-10-2003 07:43 PM
