Old 12-01-2021, 02:03 AM #1
levee-11's Avatar
levee-11 levee-11 is offline
Real Name: Levi
levee-11 is on a distinguished road
levee-11's Avatar
Real Name: Levi
5 Volts on IGT at ECU?!
Hey all, I have a crank no spark no start issue I've been tracking for over a week now. You can read the full story here:
This is my YotaTech Post
This is my T4R.org Post
I've ran out of things to test and try to get this thing to fire, and today I was trying the last of the things I can think to test, since everything has tested good, and I've not really seen any obvious issues. I tested the voltage on the black/blue wire at the Igniter, and got ~3-5V while cranking, which to my understanding is really high, as it should be 0.7-1V. I also tested at the ECU, and while cranking I was seeing about the same, with an upwards of 7V. This tells me the ECU is bad, which is the last thing I expected.
I am getting a code 14, and that code has been there for a while, even when it ran. The original 400K mile igniter died six months ago, and I'm wondering if maybe the ECU killed it with the high voltage? Truck completely died a little over a week ago now, and since everything else I've tested it good, is it safe to assume the ECU is bad? Looking for any advice or opinions as to what could be wrong here.
2002 Thundercloud Limited 3.4 4x4 M/T (Manual Swapped)
1998 Desert Dune SR5 3.4 4x4 A/T (Totalled, R.I.P)
levee-11 is offline   Reply With QuoteReply With Quote
code , ecu , igniter , post , tested
Another P0441 chase. A/F sensor at 0 volts? DerekRI 3rd gen T4Rs 3 10-03-2020 12:14 PM
17-18 Volts at the Battery blockhead 3rd gen T4Rs 16 03-23-2017 01:44 PM
Torque Pro App vs Multi-meter for Volts mtbtim 3rd gen T4Rs 23 07-09-2016 09:18 PM
What Volts does your Alternator show while charging?? ejason 5th gen T4Rs 6 05-14-2015 02:18 PM
Not getting enough volts at the fuel pump......need help 4x4runrfan Problems & Warranty Issues 6 10-17-2010 06:32 AM
