Old 02-18-2022, 05:27 PM #1
jasindude1 jasindude1 is offline
jasindude1 is on a distinguished road
Rear window not rolling down, need some guidance
I know this is a known thing, but my rear window will only roll up but not down, this recently just happened. I noticed it started to be a issue when i left the rear wiper on (there is no rear wiper) and didnt notice it till several days later since then i cant roll it down. This is where im at, the window lock is not on, the button makes a click when i press up and down and can be heard at the relay, so there is power to the button and sending signal to the relay. If i sit there and mash the down button like 30 times i can finally get it to roll down and it will work for maybe like 10 mins, anyways im gonna attempt to bypass the wiper safety today, but after that would we suspect the motor? The battery seems good im gonna do a recondition cycle as i do after the winter on all my cars. But maybe some help on other things to check since i have removed the button from suspicion, also the rear lock does the same if i turn it like 30 times it will engage. but u can hear the click.
jasindude1 is offline   Reply With QuoteReply With Quote
Old 02-18-2022, 11:27 PM #2
So i wanted to post what I tried today, after finding out the battery wires were corroded AF i fixed all that, all new terminals, proper wiring and dang my truck fires up quick now, but still no rear window down, I did direct power to the motor and both up and down work fine, I pulled the console switch and saw one of the terminals was a lil corroded, but nothing major and it was on the up wiring anyways, while messing with the switches my dash gauge lights went out, so idk. I can roll up fine, but need to mash the button like 100 times to get to go down, same with the key up works down doesnt, i can see the voltage draw on the battery gauge but only when pressing the up side, down makes the click in the back but no battery draw on gauge. Im a little lost here, if someone can help me determine the next step please
Old 02-21-2022, 07:20 PM #3
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
Drivers side B pillar there is "module" 85930-89101 probably relay inside..
SaulG is offline   Reply With QuoteReply With Quote
Old 03-19-2022, 11:36 AM #4
geezerr54 geezerr54 is offline
geezerr54 is on a distinguished road
Relay
Hey, If needed I have one of the modules from an 86. Part # 85930-89101. Let me know if you want it. Mike
geezerr54 is offline   Reply With QuoteReply With Quote
Old 04-02-2022, 04:15 AM #5
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Inspect wiring on flex harness between tailgate and body.
If both console and key switches roll window up, and both also cause the relay click but do not consistently roll down, I suspect:
1) One of the wires enclosed in red below is broken. One is Blue-Black, the other Blue-Yellow, OR
2) Relay does not properly switch up and down circuits. To test this, probe pins 1 and 3 for voltage. On UP direction you should get 12V on DOWN direction polarity would reverse (you will read -12V)
More details here: RAD4Runner's 1986 4Runner dlx Build-up - Page 40 - YotaTech Forums
Rear window not rolling down, need some guidance-rear_window_schematic-jpg
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 04-02-2022, 12:27 PM #6
kc15842 kc15842 is offline
Real Name: Kevin
kc15842 will become famous soon enough
Real Name: Kevin
How about using the keyed switch at the tailgate. Does it operate correctly?
1987 22R-E, SR5. 5 Speed, 31's BFG A/T, stock wheels. 4.56 Gears, Rear Detroit locker Front True Track. 1.5" BJ Spacers & Extended Shackles in the rear.
1992 3.0, SR5. 5 Speed. 31's BFG M/T, stock wheels. 4.30 Gears-NON ADD- manual hubs, Elocker, 1.5" BJ Spacers, Moog springs w/ spacers. Sold
kc15842 is offline   Reply With QuoteReply With Quote
Old 06-19-2022, 11:48 AM #7
Jims90 Jims90 is offline
Jims90 is on a distinguished road
Dont forget to make sure the wiper motor is in the parked position.
If not it will prevent window operations.
Mine used to be intermittent due to this issue.
When you mentioned your problems began after operation of rear wiper triggered my memory!
Jims90 is offline   Reply With QuoteReply With Quote
button , rear , roll , window , wiper
Rear liftgate window binding/not rolling up completely Koddo 5th gen T4Rs 3 11-10-2021 04:05 PM
Issue Rolling Rear Window Up With Key xwake4lifex 4th Gen T4Rs 13 05-27-2019 09:28 PM
Rear window rolling up slowly please help! dank2015 4th Gen T4Rs 2 03-12-2015 09:56 PM
Window not rolling up properly Riser 5th gen T4Rs 3 05-08-2014 09:06 PM
window is not rolling down on auto leeak47 Maintenance/Detailing 3 10-29-2011 06:54 PM
