Old 07-16-2022, 09:29 PM #16
Dylansf23 Dylansf23 is offline
Dylansf23 is on a distinguished road
Originally Posted by Dropzone View Post
SAS is an interchangeable term like SAC which a 4WUG link kit is considered.
what coil springs/bump stops/limit straps are you going with?
How about your steering system? full hydro may not be the best for a DD
Staying stock with ifs box, the 4wu kit has everything else included.
Dylansf23 is offline   Reply With QuoteReply With Quote
Old 08-22-2022, 01:10 AM #17
NotKewl's Avatar
NotKewl NotKewl is offline
Real Name: Brent
NotKewl will become famous soon enough
NotKewl's Avatar
Real Name: Brent
More Progress... Got some generic (but very useful and strong) motor mounts. We got those lined up and tacked in. Engine level pushed back properly and lined up where the hood will still shut while allowing for the most clearance for the axle.
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_5005-jpg
A little trimming of the motor mounts...
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_5011-jpg
Level the engine and tack the mounts in...
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_5015-jpg
Align the steering box mounts and tack that in...
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_5020-jpg
And yank the engine out again to burn in the right engine mount and the steering box mount. Leaving the left engine mount with just sturdy tacks because we may have to cut it depending on axle top link placement.
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_5023-jpg
My 4Runner: 2002 SR5 Project Chimera (Build Thread)
Life is short; Carpe Diem!
http://messerfab.com
NotKewl is offline   Reply With QuoteReply With Quote
Old 08-22-2022, 01:35 AM #18
NotKewl's Avatar
Real Name: Brent
NotKewl's Avatar
Real Name: Brent
Next, the engine goes back in after the mounts are welded up. And I clean up the axle and I weld in support plates to the stops.
Engine goes in but won't line up because we put on the transfer case (which later needs to come off again to clear the link mounts)
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_5030-jpg
ALMOST THERE... Just a little more!
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_5031-jpg
Stop tabs are reinforced for strength...
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_5038-jpg
Such a nice clean axle now...
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_5041-jpg
Getting the axle in place and all the link mounts mocked up. Most likely going to need to notch the frame on passenger side for maximum tuck at full bump.
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_5126-jpg
Old 08-24-2022, 07:38 AM #19
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Progress is looking good!
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 10-05-2022, 05:53 PM #20
Greasemonkey64 Greasemonkey64 is offline
Greasemonkey64 is on a distinguished road
This is way cool, I cant wait to see the end result. Best of luck!
Greasemonkey64 is offline   Reply With QuoteReply With Quote
Old 10-24-2022, 11:39 PM #21
boscounderfoot boscounderfoot is offline
boscounderfoot is on a distinguished road
Hell yes! Keep going brother. My 1uz swapped 4runner is an absolute animal. You will never regret choosing to go this route....although I kept the ifs up front and didn't cut or modify the radiator support.
Let me know if you have any questions, I fell down a few rabbit holes during my swap, maybe I can help you avoid having to go through the same crap!
Good Luck and keep it going!!
boscounderfoot is offline   Reply With QuoteReply With Quote
Old 12-24-2022, 03:21 AM #22
NotKewl's Avatar
Real Name: Brent
NotKewl's Avatar
Real Name: Brent
Back at it again
Well, we've been working on this thing on and off for a while. Thanksgiving holiday we took some time off to finish up the 3 link upfront.
Got the motor mounts situated properly. The engine goes in for the last time (at least for axle mock up and finish welding). New steering gear installed too.
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-motor-mounts-jpg
Frame strengthening plates get tacked in to mock up before finish welding.
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-side-plates-need-welding-jpg
Final check of articulation and all clearance before finish welding the axle.
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-clearence-good-jpg
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-perfect-fit-jpg
Axle out for finish welding. Adding gussets and building out the truss, etc.
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_6620-jpg
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_6633-jpg
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_6642-jpg
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_6653-jpg
Old 12-24-2022, 06:58 PM #23
NotKewl's Avatar
Real Name: Brent
NotKewl's Avatar
Real Name: Brent
My work on this project is complete. Time to see what @Dylansf23 comes up with on rear suspension and getting this beast running!
Cheers!
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap-img_6662-jpg
4runner , axle , solid , swap , toyota
Cougar House Garage 17' 5Th Gen Limited 4Runner Solid Axle Swap Build Cougar House 5th gen T4Rs 60 09-25-2018 12:16 PM
Hummer H3 Solid Axle Swap Using 4runner IFS Box kenfowler General Discussions 1 03-18-2016 08:37 AM
Solid Axle Swap 89 4Runner AUTODOK New Members 3 05-02-2012 08:14 PM
Im starting to get the 2.5yr blues...solid front axle swap or lt1 ls1 v8 swap? 240m3srt 3rd gen T4Rs 29 10-03-2011 12:15 AM
SOLID AXLE SWAP ON A 2008 4Runner WFDFIREFIGHTER 4th Gen T4Rs 5 08-10-2011 04:26 PM
