Old 04-23-2022, 05:05 AM #1
Soulprogression108's Avatar
Soulprogression108 Soulprogression108 is offline
Soulprogression108 is on a distinguished road
How to tell what gear ratio your rear diff is?
My 94 has some wear in the driveline and rear diff. I just picked up a 95 for parts and the rear axle looks the same. I’m aware that the housing was but the diffs are typically different. I’m pondering swapping them since the 95 has 75,000 leas miles but I want to know how to find out the gear ratio without opening them up.
Is it in the vin? Or any other way to tell?
Anyone know if this would be a straight swap? Thank
Current: 2011 Trail Edition T4R
Bilstein Leveling Kit: 6112's and 5160's
TRD 17" Gold Wheels 31" TA's
Sold:1994 T4R 22re 4x4 MT
Aluminum Weld 15's and 31x10.5 BFG ATs
Soulprogression108 is offline   Reply With QuoteReply With Quote
Old 04-23-2022, 08:51 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Get a rear wheel off the ground gear shift in neutral, put a chalk mark on your driveshaft lengthwise and one on the tire off the ground, then rotate the rear wheel by hand one revolution and count how many times the driveshaft rotates. The last revolution of the driveshaft will be less than one so estimate it as best you can, 3/4 turn = .75, half turn = .5, etc. My guess is it will be about 3-3/4 turns, so a 3.73 axle ratio.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 04-26-2022, 03:37 PM #3
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Check out this great classic site to help you decode the tag to find out what diffs you have. (assuming they are stock)
Gearratiosanddiffs
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
diff , gear , i’m , ratio , rear
Front diff gear ratio verification - diff removed and no vehicle info SDmtnbkr 3rd gen T4Rs 6 07-26-2017 09:39 PM
Gear Ratio in an 84 front diff bhicks22 Classic T4Rs 2 07-12-2016 06:47 PM
how to tell gear ratio (pulled diff) airdreams1 Classic T4Rs 9 01-18-2016 03:18 PM
Front diff gear ratio chris.andros.18 3rd gen T4Rs 12 12-13-2015 09:26 AM
Factory Diff Gear Ratio spencersausser 3rd gen T4Rs 3 10-10-2011 09:37 PM
