Real Name: Ron
Real Name: Ron
Get a rear wheel off the ground gear shift in neutral, put a chalk mark on your driveshaft lengthwise and one on the tire off the ground, then rotate the rear wheel by hand one revolution and count how many times the driveshaft rotates. The last revolution of the driveshaft will be less than one so estimate it as best you can, 3/4 turn = .75, half turn = .5, etc. My guess is it will be about 3-3/4 turns, so a 3.73 axle ratio.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
