Old 05-23-2022, 10:50 AM #1
ttiiggy ttiiggy is offline
ttiiggy is on a distinguished road
Coolant Out/Inlet O-Ring ?
Trying to figure out if I need an O-Ring or gasket or just use goo.
Top radiator hose, where it goes onto the engine there is an adapter...
It has a groove in it that looks like it should have a shaped O-Ring that goes in it.
No? Yes? Part number?
Blew out the bearing on the fan holder bracket, Fake water pump, I have seen it called. Took the top radiator hose off. Took off the water outlet adapter. Just has blue goo sealing it. Goo worked but is it right?
Coolant Out/Inlet O-Ring ?-outletm-gif
ttiiggy is offline   Reply With QuoteReply With Quote
Old 05-23-2022, 11:00 AM #2
4Reak Show's Avatar
4Reak Show's Avatar
Yeah it just uses sealant. Best type to use is Toyota Black FIPG (Form in place gasket I think is what that stands for).
Anyway it’s like $25 a tube or something. If you want to go cheaper, black or grey RTV from an auto parts store is fine too. Clean and dry the sealing surfaces really good. Let sealant cure awhile before adding liquid.
adapter , goo , hose , o-ring , water
Approx coolant loss when pulling the inlet to check Tstat? Endlessblockades 3rd gen T4Rs 5 10-20-2020 05:15 PM
Do I need a new water inlet? sakoluvr 3rd gen T4Rs 14 03-30-2018 04:02 PM
Torque Value for Brake Fl. Inlet UTEP 3rd gen T4Rs 0 11-15-2013 06:57 PM
Looks Like the Water Inlet O Ring.... t4rnit 4th Gen T4Rs 11 08-23-2011 05:11 PM
air inlet question Moanasdad 3rd gen T4Rs 3 01-08-2011 05:39 PM
