Old 06-28-2022, 04:20 PM #1
goatfarmer's Avatar
goatfarmer goatfarmer is offline
goatfarmer is on a distinguished road
goatfarmer's Avatar
Electrical Issue
1990 T4r/Auto/v6
Purchased the vehicle new and occasionally have removed the battery on numerous occasions, I removed the battery to charge but in the process of installing and connecting the cables far too much arcing so I immediately removed the cables and notices there is a ground wire that runs from the inner fender to the neg. side of battery burned loose so I replaced it then reconnected the cables and now I have no power to the ignition switch and blowing the 15 am fuse. The fuses in the cab appear to be fine.
I have no clue how or whether the 80, 40, or 30 amp fuses can be removed and replaced or possibly s reset mechanism in the larger what appear to be fuses in the engine compartment fuse panel??
Comment and or suggestions appreciated!!.
Dave
'The problem with engaging in useless activity is never knowing when you are done'
1990 T4r, SR5, Auto, 4X4
goatfarmer is offline   Reply With QuoteReply With Quote
Old 07-26-2022, 01:42 PM #2
jfburriss jfburriss is offline
jfburriss is on a distinguished road
The big fuses have to come out through the bottom. Remove the cover, unbolt the box from the fender, remove the bottom cover and unclip it from underneath. It should push through and exit through the bottom of the fuse box.
jfburriss is offline   Reply With QuoteReply With Quote
Old 03-01-2023, 06:55 PM #3
Batmmannn Batmmannn is offline
Batmmannn is on a distinguished road
I'm brand new so can't post a new thread. Please help.
How does a bad ground effect the EFI fuse? I have a 93 3.0 and it's blowing the EFI with every attempt at starting.
O2 sensors wires are fine. Replaced Relays, new fuel pump, disconnected AFM and VSV. No change.
Only blows when starting and not in the on position. I'm extremely frustrated. Swapped the Computer and no change.
I'm going nuts here. I can't find anything wrong but as soon as you turn the key and the starter is turning it blows the EFI FUSE.
any ideas or help would be greatly appreciated. Thanks
Batmmannn is offline   Reply With QuoteReply With Quote
battery , cables , fuses , removed , replaced
3rd gen electrical issue lord rigatoni 3rd gen T4Rs 8 11-21-2020 10:44 PM
Odd electrical issue Titanpat57 5th gen T4Rs 17 04-22-2020 04:33 PM
Electrical Issue? 1985taylor1925 3rd gen T4Rs 42 04-16-2013 07:24 PM
electrical issue 86 4 runner New Members 0 01-25-2011 10:14 AM
Electrical issue hanleysh Classic T4Rs 1 08-21-2010 07:29 AM
