Electrical Issue
1990 T4r/Auto/v6
Purchased the vehicle new and occasionally have removed the battery on numerous occasions, I removed the battery to charge but in the process of installing and connecting the cables far too much arcing so I immediately removed the cables and notices there is a ground wire that runs from the inner fender to the neg. side of battery burned loose so I replaced it then reconnected the cables and now I have no power to the ignition switch and blowing the 15 am fuse. The fuses in the cab appear to be fine.
I have no clue how or whether the 80, 40, or 30 amp fuses can be removed and replaced or possibly s reset mechanism in the larger what appear to be fuses in the engine compartment fuse panel??
Comment and or suggestions appreciated!!.
Dave
'The problem with engaging in useless activity is never knowing when you are done'
1990 T4r, SR5, Auto, 4X4
