Some more progress to report on
This time I went to my local junkyard and found a 95 with a gray interior.
Parts bought:
- Passenger door handle in gray, with rod clip
- Passenger door armrest in gray, good condition
- Dashboard hardware
- Cluster green bulbs #194 and #74
- Small plastic pocket under radio in gray
- Driver side dash vent assembly
Also found some other parts for my 89 pickup.
The 92-95 electronic VSS cluster as it currently is, as shown previously:
The green bulbs are a big deal for me and there was no way the cluster was going in the truck without them.
Here are the bulbs removed from the 2nd gen at the yard. These are the three main #194 bulbs that light up the speedo and tach. Notice the green bases.
The #194 bulbs in the 2-door’s new cluster are not green, the bulbs have a black base. Maybe these came from some another Toyota since it doesn’t look like someone just swapped the bulbs and kept the original green bases. Never knew these clusters to come with anything other than green bulbs/bases.
Bulb comparison
Bulbs swapped
There are also 4 additional smaller green #74 bulbs to illuminate the side gauges. There are 2 per side.
Upon initial testing, one of the main 3 #194 bulbs and one of the side 4 #74 bulbs were each burnt out.
After removing the non-functional #74 side bulb, it was determined to have a broken filament. With enough time and patience, I was able to remove the original green sleeve from one of the side bulbs.
The bulb is the same size as found in the lower strip of indicators on the bottom of the cluster. This truck will never need the ECT PWR lamp. It was decided to harvest this bulb.
The ECT PWR bulb is in a black base with a clear bulb, no green cover. Here it is shown left:
ECT PWR bulb, now with green cover, installed into green base to be repurposed as new side bulb.
Next up was the burned out main #194 bulb. On closer inspection, it also had a bad filament. I grabbed the original DLX tach-less cluster left over from my 89 pickup. It also uses the same size #194 bulbs in green. I pulled one bulb and installed it in the center of the 2-door cluster.
Here is the first test. The left side is now illuminated properly with the old ECT PWR bulb. Unfortunately, the color of the center pickup bulb was noticeably different than the other 4Runner bulbs.
I debated removing the green sleeve from the pickup bulb, but decided it would be best to put it back into the original pickup cluster it was removed from and leave it be.
The only option, excluding new or finding another cluster to steal bulbs from, was to use one of the three clear #194 bulbs that came out of this cluster earlier.
They turned out to be OEM and of the same power/output specification as the other #194’s in the cluster.
With more time and patience, I removed the green sleeve from the burnt 4Runner cluster bulb and installed it onto one of the 3 clears.
Final test - we’ve got matching OEM green bulbs!
Next was to go through the remaining bulbs in the dash. The HVAC control panel green bulb was dead. The glovebox lamp was working, but not green. The ashtray bulb is both green and working.
For the HVAC control panel bulb, the wires come directly from the blower motor fan switch. Thankfully, I’ve got a few of those laying around, and one of them had a good functional bulb with a green sleeve already on it. The color was spot on since it was from the identical application. The old burnt bulb was set aside as it still had a green sleeve on it that could be used elsewhere.
The last #74 that needed attention was for the glovebox. No green sleeve and clearly has been replaced with a non-OEM unit. I swapped this bulb with another unused #74 cluster bulb, this time from A/T OIL TEMP.
Now that it had an OEM bulb, it just needed to be green. The burnt HVAC bulb had a good green sleeve still left on it, and made for the perfect solution.
Green bulbs are complete!
