Old 08-16-2024, 03:55 PM #46
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
Old motor mounts removed
New motor mount vs. old
Bare rear main
Rear main retainer
FIPG
FIPG on rear main retainer
Oil strainer gasket
Oil baffle w/ FIPG
Oil pan w/ FIPG
Oil pan installed
Rear main installed
Pilot bearing installed
3.4 5VZ-FE flywheel installed, new bolts, loctite, 65ftlb
5VZ-FE bell housing brackets for R150F
Driver
Passenger
AISIN CKT-040 clutch, new pressure plate bolts, 15ftlb
Nachi throwout bearing
Throwout installed, clutch fork greased
IG: @jimharb | YouTube
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 08-16-2024, 03:56 PM #47
Moderator
Real Name: James
Moderator
Real Name: James
Truck on stands
Transmission on jack, ready for install
Transmission installed with crossmember
New view of shifter hole inside
Shifters installed
Old 08-16-2024, 03:56 PM #48
Moderator
Real Name: James
Moderator
Real Name: James
Offerup score - front mudguards
Mudguard installed, driver, w/ cap nut
Passenger
View, side
View, front
Side mirror swap, Old (top) and new (bottom)
Front view
Mirrors and flaps
Old 08-16-2024, 03:57 PM #49
Moderator
Real Name: James
Moderator
Real Name: James
Door panel, passenger, armrest swap
Panel later
Replacement door handle
Finalized door panel
Passenger seat, recline handle before
New screw for recline handle
Recline handle, after
New side window latches, not yet installed
DEPO tail lamps
Rear view
Old 09-01-2024, 05:20 PM #50
Moderator
Real Name: James
Moderator
Real Name: James
Filled with oil - 5W-30 full synthetic
Refused to start. Test of fuel pump through diagnostic connector came up with nothing. No fuel pressure, no noise from pump.
Tank pulled
Pump removal
Rusty pump
Removed pump, cleaned hanger
Used 5VZ pump, had in storage for years
New fuel pump harness from Walbro kit
New pump in hanger
Soldering wires
Old 09-01-2024, 05:21 PM #51
Moderator
Real Name: James
Moderator
Real Name: James
Moog 285 Greaseable U-Joints
Used driveshaft from 93 Pickup regular cab short bed, perfect length but with the wrong flanges
Installing new joints
Slip yoke with joint removed, correct flange
Shaft complete with 1990 flanges from original auto shaft
Joint 1
Joint 2
Shaft installed
Front diff installed
New AISIN slave cylinder
IT’S ALIVE!
Old 01-31-2025, 03:00 AM #52
Moderator
Real Name: James
Moderator
Real Name: James
Quick wash
New 555 ball joints
Coated in POR 15 (some other parts for other projects shown as well)
New 555 outer tie rods, pitman arm, coated in POR 15
New power steering pump, coated in POR 15
New 555 outer tie rod ends, coated in POR 15
New 555 idler arm, coated in POR 15
Nice to have it semi-driving, still work left to be done before it’s completely ready to be a driver
Old 01-31-2025, 03:01 AM #53
Moderator
Real Name: James
Moderator
Real Name: James
Supra outside, painting the house
Hard parked, night time
Day time
Old 01-31-2025, 03:03 AM #54
Moderator
Real Name: James
Moderator
Real Name: James
Pressure wash suspension, engine bay, prepping for new ball joints and tie rod ends
Repaired side window latch. New aftermarket xtra-cab latch did not fit. I swapped the new plastic handle onto the original 2-door latch metal. It’s not an exact match, but at least now it works.
Daytime shots
Old 01-31-2025, 03:05 AM #55
Moderator
Real Name: James
Moderator
Real Name: James
Dashboard reinstalled
VSS harness, made from a VSS plug and sections of colored wire from an old 4Runner body harness
12V+ Pin 1 (black yellow)
Ground Pin 2 (pink blue)
Signal Pin 3 (gray blue)
Plugged into VSS
Run along old speedometer cable route
Pinned into OEM 1990 combination meter plugs
12V+ sourced from GAUGE fuse, connector A, pin #8
Speed sensor ground, connector B, pin #10
Speed meter signal (SIG-VAL), connector A, pin #1
Functional speedometer, TRIP, and ODO
Old 01-31-2025, 03:07 AM #56
Moderator
Real Name: James
Moderator
Real Name: James
Transfer case switch. Did not have other end to the plug, instead I removed the pins and swapped to another plug housing from a turn signal lamp.
Original female plug housing:
Replacement female plug housing sourced from turn signal:
Connected to opposing male plug housing with extra wire:
Transfer case switch connects to 3 total wires, located in automatic transmission blue 6-pin plug.
The following two wires must be connected to one transfer case switch wire (doesn’t matter which).
Pin #2, pink w/ blue stripe, automatic disconnecting differential detection switch
Pin #4, green w/ white stripe, transfer case detection switch
(Before soldering)
Second wire of transfer case switch connects to ground, which is the remaining white w/ black stripe wire cut previously from the blue plug.
Engaging 4HI from the transfer case shift lever will now result in automatic disconnecting differential system engaging the front differential to driveshaft, as well as 4WD light illuminating on combination meter/gauge cluster.
Old 01-31-2025, 03:08 AM #57
Moderator
Real Name: James
Moderator
Real Name: James
Reverse light switch connects to 2 total wires, located in automatic transmission large white plug (P1 connector). Doesn’t matter which side of the switch you connect them. It’ll work either way. Connect one of the following to each side of the reverse light switch:
Pin # 4 (black w/ orange stripe)
Pin # 8 (red w/ white stripe)
Connected:
I left the auto plugs hanging and zip tied the wires together to clean things up:
Reverse lights working with shifter in reverse position:
Further dash reassembly
Old 02-06-2025, 01:28 AM #58
Moderator
Real Name: James
Moderator
Real Name: James
Front driveshaft installed
Time to refresh steering and front suspension joints
Upper ball joint removed
Idler arm removed
Tie rods removed
Old units
New upper ball joint installed
New 555 idler installed
New tie rods installed
Lower ball joint comparison
New lower installed
Full shot
New shock stem bushings, energy suspension polyurethane
Pitman arm comparison
New pitman installed
Old 02-06-2025, 01:29 AM #59
Moderator
Real Name: James
Moderator
Real Name: James
New full body shots
Old 02-07-2025, 11:33 PM #60
Moderator
Real Name: James
Moderator
Real Name: James
Steering stop caps
Off to the Toyota dealer to get a new center link and alignment for free to due recall
Went back the next day and picked it up
Wheels aligned, steering wheel nice and straight
Got home and realized the front bumper valance had a big dent in it. Talked to the dealer and they’re going to review their cameras and see what happened. I had pics showing the truck at drop off so there’s no doubt that the dent wasn’t there before.
3rd , 4runner , gen , idea , swap
FS 2nd Gen 1990 4-door MARYLAND $4000 caspice For Sale: Vehicles 1 06-10-2019 11:52 AM
1990 4Runner 2 door - 1UZ-FE V8/5 speed swap. Dunkin Classic T4Rs 15 12-19-2013 02:22 AM
Craigslist Find: 1990 2 door in FL thegray1 Classic T4Rs 10 09-30-2013 07:47 PM
1990 two door 4 Runner 2003-4x4runner Classic T4Rs 4 01-13-2011 12:38 PM
1990 4Runner 4x4 - 2 Door DaddyOutlaw Classifieds - buy & sell (no commercial ads please) 0 04-03-2010 04:22 PM
