Old 03-23-2021, 11:48 AM #1
4x4withcheese 4x4withcheese is offline
4x4withcheese is on a distinguished road
1995 3.0l V6 Manual engine swap
Hello, I recently found out that my 3vze has water leaks from the cylinder head and hot water control valve, I知 going to have to drive it until I can afford to swap the engine but I知 wondering what engines would be the easiest to have swapped. Easiest meaning the least cutting in the engine bay and preferably compatible with the stock 5-speed manual transmission. I believe the trans is the r150f. I was thinking an LS of some sort and if I知 going to do a swap I don稚 want to make the same trash power I made before so something with more power and mod capability is preferred.
1995 4x4 4Runner Manual 3L V6
4x4withcheese is offline   Reply With QuoteReply With Quote
Old 03-23-2021, 04:54 PM #2
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
5VZ-FE. 3.4l
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 02:58 PM #3
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Easy depends on your skill level. Saying Easy, then saying LS is contradicting. Haha.
I agree with dropzone. The 3.4 (5vzfe) will definitely be the most straight forward swap.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 03-09-2022, 04:53 PM #4
95'2WD 95'2WD is offline
95'2WD is on a distinguished road
4x4with cheese,
Did you go through with it?
Regards,
95'2WD
95'2WD is offline   Reply With QuoteReply With Quote
Old 08-29-2023, 09:24 PM #5
Originally Posted by 95'2WD View Post
4x4with cheese,
Regards,
95'2WD
No I didn稚, I couldn稚 afford it and didn稚 have anywhere to work on it. But I ended up with the exact same one exact a 94 instead of 95, and am doing the head gaskets and almost a whole restoration.
Old 08-31-2023, 02:02 PM #6
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
I did the swap about a year ago. Did it cheap, swapping in the whole donor harness. Came out great and the power is awesome.
I was a diehard 3.0 fan, now a 3.4 fanboi
I dont update here much anymore, but details over on irate...
"The Blue Truck" | irate4x4
IG: rattlewagon
engine , i知 , power , swap , water
2000 to 1995 engine swap...possible? akyota Classic T4Rs 8 06-28-2015 02:28 AM
1995 4runner engine swap countryboy0709 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 06-23-2015 01:10 AM
Need Advice on 1995 4Runner. Piece out or Swap Engine?? HungerGames Classic T4Rs 8 09-25-2013 06:06 PM
1995 4 runner engine swap I need some advice izzy434 Classic T4Rs 6 09-22-2010 02:16 AM
1995 V6 Engine swap is Tougher than Tough izzy434 Classic T4Rs 1 09-16-2010 11:32 AM
