Old 08-16-2024, 03:55 PM #46
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
Old motor mounts removed
New motor mount vs. old
Bare rear main
Rear main retainer
FIPG
FIPG on rear main retainer
Oil strainer gasket
Oil baffle w/ FIPG
Oil pan w/ FIPG
Oil pan installed
Rear main installed
Pilot bearing installed
3.4 5VZ-FE flywheel installed, new bolts, loctite, 65ftlb
5VZ-FE bell housing brackets for R150F
Driver
Passenger
AISIN CKT-040 clutch, new pressure plate bolts, 15ftlb
Nachi throwout bearing
Throwout installed, clutch fork greased
IG: @jimharb | YouTube
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 08-16-2024, 03:56 PM #47
Moderator
Real Name: James
Moderator
Real Name: James
Truck on stands
Transmission on jack, ready for install
Transmission installed with crossmember
New view of shifter hole inside
Shifters installed
Old 08-16-2024, 03:56 PM #48
Moderator
Real Name: James
Moderator
Real Name: James
Offerup score - front mudguards
Mudguard installed, driver, w/ cap nut
Passenger
View, side
View, front
Side mirror swap, Old (top) and new (bottom)
Front view
Mirrors and flaps
Old 08-16-2024, 03:57 PM #49
Moderator
Real Name: James
Moderator
Real Name: James
Door panel, passenger, armrest swap
Panel later
Replacement door handle
Finalized door panel
Passenger seat, recline handle before
New screw for recline handle
Recline handle, after
New side window latches, not yet installed
DEPO tail lamps
Rear view
Old 09-01-2024, 05:20 PM #50
Moderator
Real Name: James
Moderator
Real Name: James
Filled with oil - 5W-30 full synthetic
Refused to start. Test of fuel pump through diagnostic connector came up with nothing. No fuel pressure, no noise from pump.
Tank pulled
Pump removal
Rusty pump
Removed pump, cleaned hanger
Used 5VZ pump, had in storage for years
New fuel pump harness from Walbro kit
New pump in hanger
Soldering wires
Old 09-01-2024, 05:21 PM #51
Moderator
Real Name: James
Moderator
Real Name: James
Moog 285 Greaseable U-Joints
Used driveshaft from 93 Pickup regular cab short bed, perfect length but with the wrong flanges
Installing new joints
Slip yoke with joint removed, correct flange
Shaft complete with 1990 flanges from original auto shaft
Joint 1
Joint 2
Shaft installed
Front diff installed
New AISIN slave cylinder
IT’S ALIVE!
3rd , 4runner , gen , idea , swap
FS 2nd Gen 1990 4-door MARYLAND $4000 caspice For Sale: Vehicles 1 06-10-2019 11:52 AM
1990 4Runner 2 door - 1UZ-FE V8/5 speed swap. Dunkin Classic T4Rs 15 12-19-2013 02:22 AM
Craigslist Find: 1990 2 door in FL thegray1 Classic T4Rs 10 09-30-2013 07:47 PM
1990 two door 4 Runner 2003-4x4runner Classic T4Rs 4 01-13-2011 12:38 PM
1990 4Runner 4x4 - 2 Door DaddyOutlaw Classifieds - buy & sell (no commercial ads please) 0 04-03-2010 04:22 PM
