Old 09-08-2022, 09:27 PM #1
lyndeba lyndeba is offline
lyndeba is on a distinguished road
Window Switch
‘89 4Runner Window Switch. Can anyone help me on how to remove this switch panel? Do I need to remove the door card?
I’m thinking I have a bad contact. Passenger window works, door lock works and when I press the up button, it’s drawing power because the door light dims. However, it doesn’t dim when I press down.
I’ve owned the truck for 20 years. I’m not mechanically inclined, which is why I enjoy owning a Toyota. Appreciate any insight.
Window Switch-16eb0f1e-c362-4806-9388-4588d25e84dc-jpg
lyndeba is offline   Reply With QuoteReply With Quote
Old 09-08-2022, 09:38 PM #2
wallytoo's Avatar
wallytoo wallytoo is offline
wallytoo has a spectacular aura about wallytoo has a spectacular aura about
wallytoo's Avatar
just pry up gently on the switch assembly, no need to remove the door card.
member, new hampshire timberland owners association (NHTOA)
1987 4runner sr5, 22re, 5-speed
1988 4runner sr5, 3.0, auto (parts rig)
1987 4runner, sr5, 22re, 5-speed (#2)
wallytoo is offline   Reply With QuoteReply With Quote
Old 09-09-2022, 06:09 AM #3
Thanks Wally. Any particular place to start or clips to look out for? After over 30 years, the plastic is brittle.
Old 09-30-2022, 08:25 PM #4
boscounderfoot boscounderfoot is offline
boscounderfoot is on a distinguished road
Don't attempt to pry that switch out of the door card....ask me how I know this....Those are screwed in from below and require you to pull the door card to access. That entire switch disassembles as one piece. When I cleaned mine up, I used 1000 grit sandpaper on the contacts followed by a pencil eraser. Everything works flawlessly now. If your door card plastic clips break or are missing, Toyota has the stock replacements at a reasonable cost, so much so that I bought enough to repair both doors if necessary.
boscounderfoot is offline   Reply With QuoteReply With Quote
door , remove , switch , window , works
Tailgate / back window doesn't work (motor works and it isn't the window lock switch) seattlee 3rd gen T4Rs 17 04-03-2022 08:58 PM
4WD selector switch light/Rear window light switch replacement Ventil8 4th Gen T4Rs 22 10-09-2020 11:24 PM
2014 4runner 4x4 switch and rear window switch doesn't light up? slee05 5th gen T4Rs 5 06-28-2014 05:10 PM
1991 T4R - Rear Window Switch and Window Lock Switch ? El_Estrago Classic T4Rs 0 07-25-2011 04:03 AM
rear window switch, sunroof switch cdmasm Classic T4Rs 2 07-06-2006 04:23 PM
