Old 10-06-2008, 07:54 PM #1
Arthur Dent Arthur Dent is offline
Arthur Dent is an unknown quantity at this point
Brake problems
I'll be acquiring an '88 4Runner relatively soon. But it has brake problems. The pedal is real mushy and doesn't really stop with much power, it stops, it just takes a while. Any suggestions where to start or what the problem may be?
Thanks.
I'm new here, by the way.
Arthur Dent is offline   Reply With QuoteReply With Quote
Old 10-06-2008, 07:57 PM #2
hickory's Avatar
hickory hickory is offline
hickory is an unknown quantity at this point
hickory's Avatar
brakes
Their could be air in the system that would require bleeding. Could also be the booster which I know nothing about yet.
Can't see the forest for the trees
hickory is offline   Reply With QuoteReply With Quote
Old 10-07-2008, 02:06 PM #3
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
Start by bleeding them, may have to do it a few times.
If the fluid is dirty, it's good to keep bleeding them until new fluid comes out all bleeder valves (be sure to keep the Master Cylinder full).
While someone puts pressure on the pedal, check all the rubber hoses (2 front, 1 rear) to make sure they aren't expanding under pressure.
Proper order is: LR, RR, RF, LF, LSPV
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 10-07-2008, 07:08 PM #4
Thanks, guys.
On the off-chance it needs a master cylinder how much do those run? And what sort of work might the brake booster need?
Sorry to be pestering with the questions.
Old 10-07-2008, 08:22 PM #5
hickory's Avatar
hickory's Avatar
brakes
I bought a used master cylinder for $75 CAD. Sorry I don't know a thing about brake boosters.
Old 10-08-2008, 08:09 AM #6
ronbo613 ronbo613 is offline
ronbo613 is an unknown quantity at this point
Push down hard on the brake pedal. If the brake pedal goes slowly to the floor, it is probably the master cylinder.
If the brake pedal gets better as you pump it, it is most likely air or water in the brake lines or wheel cylinders.
Replacing a master cylinder is not a tough job at all. You don't even have to crawl under the vehicle until you bleed the brakes. A rebuilt master cylinder should be less than $100.USD.
WatermanAtWork
1995 4Runner SR5
ronbo613 is offline   Reply With QuoteReply With Quote
Old 10-08-2008, 08:57 PM #7
Thanks again. Looks like I'll be getting the 4Runner soon.
Old 05-20-2012, 05:41 PM #8
w_hudson w_hudson is offline
w_hudson is on a distinguished road
But d not rule out the rear wheel cyliners if those are leaking, your pedal will never be right
w_hudson is offline   Reply With QuoteReply With Quote
Old 05-20-2012, 08:24 PM #9
USE911's Avatar
USE911 USE911 is offline
USE911 is on a distinguished road
USE911's Avatar
Be sure to post pictures when you bring it home.
1989 4runner 22re 5sp, 4inch susp, 3 body, 2in extended shackle in rear, 35inch kumho mt's 5 29s, Yukon Grizzly locker in rear
1986 4runner 22re 5sp STOCK
1982 Toyota P/U 3.8l Buick 4inch lift, 38's
USE911 is offline   Reply With QuoteReply With Quote
Old 05-20-2012, 09:29 PM #10
Bad_Vision's Avatar
Bad_Vision Bad_Vision is offline
Bad_Vision is on a distinguished road
Bad_Vision's Avatar
new master cylinder 43$
RockAuto Auto Parts its a cardone re manufactured with reservoir
brake fluid should be changed every year.
Classic's Section Moderator
http://www.4crawler.com/4x4/CheapTricks/index.shtml
My 1985 TDI swapped 4Runner http://www.toyota-4runner.org/classi...-tdi-swap.html
Bad_Vision is offline   Reply With QuoteReply With Quote
Old 05-20-2012, 09:44 PM #11
SV_Dude SV_Dude is offline
Moderator
Real Name: Jonathan
SV_Dude will become famous soon enough
Moderator
Real Name: Jonathan
Not to burst anyone's bubble but this thread is almost 4 years old.
SV_Dude is offline   Reply With QuoteReply With Quote
Old 05-20-2012, 09:55 PM #12
Bad_Vision's Avatar
Bad_Vision's Avatar
hahaha holy **** i didnt even look at that whos the dink that restarted this?
Old 05-21-2012, 03:19 AM #13
tor-redneck's Avatar
tor-redneck tor-redneck is offline
tor-redneck is on a distinguished road
i blame hudson. nice 1st post lol. i couldnt figure out my brake problems untill i finaly noticed my rear brake adjester was backing off. clicker would allow it to spin backwords. (kinda like my spelling)
tor-redneck is offline   Reply With QuoteReply With Quote
Old 09-08-2022, 05:56 PM #14
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
Bubble is burst but now it's another 10 years old! Still useful.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Brake Assist...what is it?? Thai 4th Gen T4Rs 3 02-01-2022 03:24 PM
Dynamic Rear Proportioning (aka EBD) Thai 4th Gen T4Rs 1 06-20-2011 09:24 PM
Problems with aftermarket brake pads? speedracer33 4th Gen T4Rs 8 11-21-2006 02:27 PM
First time towing and having brake light problems! Oscar Maintenance/Detailing 8 01-31-2006 03:28 PM
Disc & Drum Brakes Thai Maintenance/Detailing 0 11-20-2002 04:32 PM
