Old 01-29-2023, 11:45 PM #1
Euston Euston is offline
Euston is on a distinguished road
CLunking and THunking
Hi guys,
I've searched here and only came up with info from years ago...
I've got some Clunking and Thunking from the underside of my 94 4Runner 3.0 Manual.
At first it felt like the rear axle was going to leave my truck...
I installed new Bilstein shocks on all 4 corners and it made it better but still bad
I then installed swaybar mounts and end links poly bushings from Energy Suspension. That made a big difference in the rear axle play.
I then installed the rear control arm bushings and that made a Yuge difference.
BUT I'm still dealing with a thud and bang in the rear and I cant figure it out. I've got Old Man Emu springs in the back and I thought that they're just over powering the bounce back and that is what the thud is?
The spare wheel is tight, I've checked all the bolts and nuts for the shocks and they're all tight... Its got a 1" body lift and all those bolts are tight...
I'm lost, can anyone help with anywhere else to check?
I have not checked the wheel bearings or anything like that....
Thanks in advance
Euston is offline   Reply With QuoteReply With Quote
Old 01-30-2023, 12:09 AM #2
Old 02-01-2023, 01:37 PM #3
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Jack and tools all tight? transmission mounts?
Does it happen more around corners? Can you put it up on jackstands and shake stuff to try to recreate it?
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 02-02-2023, 05:01 PM #4
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
It's been asked but under what circumstances does it clunk? Will it do it if you left foot brake? Forward? Reverse?
How is the propeller shaft bearing? The U-Joint?
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 02-02-2023, 05:07 PM #5
Reinout's Avatar
Real Name: Reinout
Reinout's Avatar
Real Name: Reinout
installed , made , rear , shocks , tight
Low Speed Clunking Unner 3rd gen T4Rs 36 06-24-2017 11:24 AM
Front End Thunking Noise Rverrat Cargel 3rd gen T4Rs 19 09-10-2015 11:16 AM
Clunking noise sdhobbs 5th gen T4Rs 9 07-24-2014 11:45 PM
Vibration and clunking SilentYoda3 3rd gen T4Rs 9 03-30-2014 05:01 PM
Clunking from the brakes... tomhaney1 Problems & Warranty Issues 2 02-10-2008 04:00 PM
