04-25-2024, 03:57 PM
minor emergency currently broke down please advise thanks!
my friend just left my house after visiting on her roadtrip and made it only about 20 miles away up the mountain (i live in arizona) she and her kid hitchhiked back and we are now going back out to try and figure out the problem
here's the info I have so far, will update:
1985 toyota 4runner
going down hill, extreme grinding sound
she would stop accelerating and then it would whine loudly
but when she came out of gear all the bad sounds would stop
but then she would lose power to Steering AND brakes
but like intermittently or like flickering in and out
but she was still able to downshift and did not stall
still running, still has electric, but couldn't keep driving without the brakes.
I'm confused because AFAIK the power and brakes should be completely independent systems although I did read that maybe the ABS uses power from the steering on some models?
all tips welcome hoping to avoid a long delay and mechanic visit.
Thanks!
04-25-2024, 04:45 PM
Real Name: Ron
Real Name: Ron
Wild guess, but did a brake fail, such as a pad going full metal contact, resulting in noise, erratic braking?
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
04-25-2024, 06:59 PM
Seriously doubt there is any electrical assistance to steering or brakes in a 1985 vehicle. AFAIK brakes would be vacuum assisted and power steering hydraulic.
Losing ABS (if equipped) should not disable the brakes, just the ABS function.
I wish I were more familiar with this age 4runner to give you more assistance, hopefully someone more knowledgeable will chip in.
04-26-2024, 03:42 PM
The truck has been moved to a mechanic.. we got out there and looked it over but couldn't find any external problems. I believe a rattling sound is coming from inside the motor.
04-26-2024, 05:43 PM
official vendor
official vendor
not sure why a internal motor problem would cause steering/braking issues. and in an 85 the brakes arent electric so that seems odd
04-27-2024, 03:15 PM
Moderator
Real Name: The Chosen One
Moderator
1985 toyota 4runner
Thanks!
Brakes and steering are 2 different systems. Brakes have a vacuum power assist and the power steering has a belt driven pump. Both require the engine to be running for the power assist functions to work. Both will work without engine running but require a lot more effort to work. No ABS on an '85.
'89 4Runner SR5 - stock
04-27-2024, 03:19 PM
Moderator
Moderator
There's many internal engine problems that could make noise, but the most common would be a worn/loose timing chain slapping inside the timing chain cover. The chain should be replaced every 100-115K miles or so, has that ever been replaced?
