Old 04-25-2024, 03:57 PM #1
jmauer jmauer is offline
jmauer is on a distinguished road
minor emergency currently broke down please advise thanks!
my friend just left my house after visiting on her roadtrip and made it only about 20 miles away up the mountain (i live in arizona) she and her kid hitchhiked back and we are now going back out to try and figure out the problem
here's the info I have so far, will update:
1985 toyota 4runner
going down hill, extreme grinding sound
she would stop accelerating and then it would whine loudly
but when she came out of gear all the bad sounds would stop
but then she would lose power to Steering AND brakes
but like intermittently or like flickering in and out
but she was still able to downshift and did not stall
still running, still has electric, but couldn't keep driving without the brakes.
I'm confused because AFAIK the power and brakes should be completely independent systems although I did read that maybe the ABS uses power from the steering on some models?
all tips welcome hoping to avoid a long delay and mechanic visit.
Thanks!
jmauer is offline   Reply With QuoteReply With Quote
Old 04-25-2024, 04:45 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Wild guess, but did a brake fail, such as a pad going full metal contact, resulting in noise, erratic braking?
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 04-25-2024, 06:59 PM #3
beautifulbrick beautifulbrick is offline
beautifulbrick is on a distinguished road
Seriously doubt there is any electrical assistance to steering or brakes in a 1985 vehicle. AFAIK brakes would be vacuum assisted and power steering hydraulic.
Losing ABS (if equipped) should not disable the brakes, just the ABS function.
I wish I were more familiar with this age 4runner to give you more assistance, hopefully someone more knowledgeable will chip in.
beautifulbrick is offline   Reply With QuoteReply With Quote
Old 04-26-2024, 03:42 PM #4
The truck has been moved to a mechanic.. we got out there and looked it over but couldn't find any external problems. I believe a rattling sound is coming from inside the motor.
Old 04-26-2024, 05:43 PM #5
Offroad Alliance Offroad Alliance is offline
official vendor
Offroad Alliance is on a distinguished road
official vendor
not sure why a internal motor problem would cause steering/braking issues. and in an 85 the brakes arent electric so that seems odd
Offroad Alliance is offline   Reply With QuoteReply With Quote
Old 04-27-2024, 03:15 PM #6
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
1985 toyota 4runner
Thanks!
Brakes and steering are 2 different systems. Brakes have a vacuum power assist and the power steering has a belt driven pump. Both require the engine to be running for the power assist functions to work. Both will work without engine running but require a lot more effort to work. No ABS on an '85.
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 04-27-2024, 03:19 PM #7
fourwd1's Avatar
Moderator
Moderator
fourwd1's Avatar
There's many internal engine problems that could make noise, but the most common would be a worn/loose timing chain slapping inside the timing chain cover. The chain should be replaced every 100-115K miles or so, has that ever been replaced?
Old 05-15-2024, 01:39 AM #8
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
1985 toyota 4runner
Thanks!
Given the symptoms, it could be a problem with the powertrain or drivetrain. Probably, there's an issue with the transmission, differential, or even the transfer case. Also, maybe, check the transmission fluid level and condition.
Regarding the power loss to both steering and brakes, while these systems are typically independent, there could be a common issue affecting both. This be a problem with the power steering pump or a vacuum leak messing with the brake booster.
As for the rattling sound coming from inside the motor, this could mean an internal engine issue, like maybe, a worn-out bearing, piston slap, or even a damaged valve train component.
weberlukas74 is offline   Reply With QuoteReply With Quote
back , brakes , power , steering , stop
2015 TRD Pro - Broke front spring? (broke while parked in garage) rustbeltboss 5th gen T4Rs 20 02-24-2021 11:53 AM
Minor accident. What would you do? depth 4th Gen T4Rs 35 01-14-2021 09:18 AM
New-To-Me 98 SR5/Minor Build Possible bergeron37 3rd gen T4Rs 2 02-24-2013 09:55 PM
Minor Skidplate Mod CJ3Flyr 4th Gen T4Rs 19 03-24-2009 08:20 PM
97-SR5, Need help with some minor repairs 4Rummer 3rd gen T4Rs 0 04-19-2006 05:37 PM
