У нашего провайдера существует разограничение на российский/зарубежный трафик.
К сожалению для IP 71.103.14.167 доступ закрыт.
"Российским" считается трафик от любого объекта сети, IP-адрес которого попадает в список "российских" IP-сетей провайдера.
Список IP-адресов стран СНГ обновляется из публикуемых списков IP-адресов соответствующих стран.
Проверить принадлежность вашего IP вы можете по базе WHOIS RIPE NCC
this is what I'm gettting
/l/l@tT
1990 4Runner 4x4 = My lil Tank
2006 GsxR 600 = Personal Ticket Dispenser
Any idea where 17341E hoses come from... They are just laying on the ground... LOL when I figure those 2 hoses I'm done. The rest I can figure out based on that pic u gave me. Thanks Den You rock
/l/l@tT
Originally posted by K_Labs Any idea where 17341E hoses come from... They are just laying on the ground... LOL when I figure those 2 hoses I'm done. The rest I can figure out based on that pic u gave me. Thanks Den You rock
it is power steering pump, vacum hose of air control valve
Wow thanks again den! I contacted a fellow forum member and I am going over to his house to see how the rest of the hoses are hooked up. So I can stop wasting every1 else's time.
/l/l@tT
Man if you solve the problem with ground wire please give me pics!
I'm lookin through the wiring diagram right now... But I still have the old engine so maybe I can find a bolt that is loose and figure it out like that. The problem is that it is raining for a little bit here and the ground is still wet. I don't wanna crawl under the car. I maybe found something in the wiring diagram......
/l/l@tT
It is in the example of the HOW TO READ THIS SECTION...
In conclusion Dr. Morbius should be given a medal! It says "(K) indicates ground point" then in small print it says " \c/ : Located on engine block"
/l/l@tT
