Im confused, On the timing chain itself. (once you get to, or near TDC) there is a discolored link (lighter in color) right? Is there one or two?
I have a repair manual that shows two discolored links, but on this image below it only shows one.
http://www.4x4wire.com/toyota/mainte...n/image006.jpg
If it has one tis directly over the notch on the camshaft sprocket, if it has two they are evenly over the notch and the notch is inbetween the links.
WHich one is correct?
Btw how do u get it EXACTLY TDC?
I can only get really close like the camshaft notch is at 11 or 1 or clock not straight up
EDIT:
Okay now I show some manual it looks like online.
http://yotarepair.com/22R%20timingchain.html
Page 4 of the pictures. 2nd picture of the page, the picture of the timing chain placement on the camshaft sprocket. It shows two colored links inbetween the marks not directly ontop.
