01-18-2008, 12:36 PM
Odometer, Speedometer, other dash guages not working
Yesterday, I noticed on my 1995 4Runner that the Speedometer, Odometer, and other front guages are not operating. I called my mechanic and they told me they would have to run a $70 diagnostic test, and then hopefully diagnose the problem. They told me it most likely has to do with the wiring. Has anyone else experienced this problem? I found it especially odd that the overall mileage guage is not operating. Any help or ideas would be great. Thanks!
01-18-2008, 12:51 PM
I would start by checking all fuses, both underhood and in the truck. Once you have isolated the problem to a particular fuse/s you can then check the wiring associated with that fuse block. I hope this helps.
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
01-18-2008, 02:00 PM
Yeah I agree blown fuses most likely! Go buy yourself a fuse tester for 5 dollars and save yourself 65. < Not necessary but just putting it into perspective for you!
/l/l@tT
1990 4Runner 4x4 = My lil Tank
2006 GsxR 600 = Personal Ticket Dispenser
01-18-2008, 02:04 PM
Agreed. I would check the fuses first. Very unlikely but could some of the connections going into the back of the gauge cluster have come lose?
Are the 1995 Runner's OBDII?
01-18-2008, 04:31 PM
Moderator
Real Name: The Chosen One
Moderator
OBD II did not come out until 96.
A bad ground at the inst panel is fairly common, and would make lights and/or gauges inoperable.
'89 4Runner SR5 - stock
01-19-2008, 01:19 AM
That's what I thought. So I was wondering why it would cost $70 to "diagnose" the problem. I wonder what they would do for 70$?
04-29-2023, 04:36 PM
Real Name: Reinout
Real Name: Reinout
I know this is ancient history, but I'm trying to diagnose the instrument panel not working: where does the panel ground?
Edit: Update: I replaced the Ignition fuse (which wasn't blown), but it fixed the majority of the issues. I'll go in and replace the rest of the old fuses since it's cheap insurance.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reason: update
07-17-2023, 10:10 PM
On the 98 I had, a fuse connection went bad when I stopped to take a call. When I eventually figured it out, the fuse was good, and removing it and putting it back in was all it took. And 4-6 hours to get to that point.
On my 92 the speedometer is having issues when "cold". Sounds like it is the Vehicle Speed Sensor. Maybe a removal and cleaning will be all it takes, but there are replacements on Amazon and Rock Auto. But my odometer is working even when the speed is shown at 0, and I think the lights are all working on the instrument panel, so my problem is a little different. Still, not a bad idea to pull and reinsert fuses once in a while, especially in wet or humid areas.
92 4runner SR5 Garnet Pearl (3K3), 5spd 4x4 V6 185k
22 Sienna AWD 9k
06 Sienna AWD 185k
98 4runner SR5 4x4 V6 auto 136k locking rear diff -- SOLD (and heard it's been totaled)
07-21-2023, 07:52 PM
Real Name: Reinout
Real Name: Reinout
I did that as well and even pulled the old fuses and just replaced them with brand new ones. I'll chase it down at some point: there are other things to worry about. At least on the outside of the car the turn signals and brake lights work.
07-29-2023, 03:04 AM
Having the same issue if anyone can share some links to parts. I have a 95 4runner running diesel and the speedometer struggles to rise.
