I have a '95 4Runner with the check engine light on. The car also has a rough idle. After checking the computer for codes, I got codes 25 and 26. My Haynes book has these two diagnosis: 1)When the air-fuel ratio feedback correction value or adaptive control valve fedback frequency is abnormally high during feedback condition. 2)Open circuit in oxygen sensor signal (Ox).
For trouble areas it suggests checking: 1)Injector circuit, 2) Injector, 3)Fuel line pressure, 4)Oxygen sensor circuit, 5)Oxygen Sensor, 6)Air flow meter, 7)Water temperature sensor, 8)Cold start injector
A friend who works on cars a lot said he's sure it's the oxygen sensor. I know I can buy an OEM O2 sensor at this website for about $100:
http://www.1sttoyotaparts.com/part_number.html
My question is do you guys agree with my friend and just buy the O2 sensor or should I be checking some of those other things out first.
