ill answer u best i can...
the ECT controls the transmision . i use it to save gas, and when im patient. when im in a hurry i turn it off ,the light turns on @ the dash and its worse on gas but drives more normal in my opinion.
overdrive i use when ever i can ,but if your truck shifts alot and is under powered like most of the 3.sLow engines R it just helps heat up the transmission shifting back and forth.and cause more wear and tear.
if u tow something i would turn OD it off. should run warmer towing, up big hills but not much ...i tow my snowmobile so maybe totals at 1200-1800 lbs trailer n all ,and i dont know its there.
not sure the max tow capacity .
