Old 07-26-2008, 04:48 PM #1
Arctic 4x4 Arctic 4x4 is offline
Arctic 4x4 is an unknown quantity at this point
Running Rich... How to adjust?
My 90 T4R 3VZ-E idles rough, eats a ton of gas, and gives me the impression that it is running rich.
Are there any ways to adjust the fuel/air mixture or something to keep it from running rich?
Arctic 4x4 is offline   Reply With QuoteReply With Quote
Old 07-27-2008, 04:39 PM #2
1992-4r 1992-4r is offline
1992-4r is on a distinguished road
i dunno, i was wondering that myself i think my 92' is runnin alittle rich too... i can smell a real strong gas smell when i roll my back window down...
1992-4r is offline   Reply With QuoteReply With Quote
Old 07-27-2008, 10:25 PM #3
Sidney Sidney is offline
Sidney is an unknown quantity at this point
Pull the ECU codes and measure voltages/resistances at ECU (EFI computer) and compare with FSM (factory service manual):
Free 1990 Toyota 4-Runner Factory Service Manual:
http://rapidshare.com/files/34006966...0.1995.SIL.rar
To pull the ECU codes:
All 1980-1995 and including 1995 EFI equipped vehicle allow you to find engine and related faults by pulling the ECU (computer) codes without the need for a handheld OBDII diagnosis scanner, the sites listed below have the fault codes needed to pull the codes and the instructions on how to do it:
http://autorepair.about.com/library/...bl-dtcs-36.htm
http://autorepair.about.com/library/...bl-dtcs-53.htm
http://autorepair.about.com/library/...bl-dtcs-71.htm
http://autorepair.about.com/library/...bl-dtcs-90.htm
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
http://www.off-road.com/toyota/tech/codes/index.html
http://www.4crawler.com/4x4/CheapTri...CheckConnector
http://www.4crawler.com/4x4/CheapTri...osticcodes.gif
http://lcengineering.com/TechNotes/TechNote12.htm
http://lcengineering.com/TechNotes/TechNote13.htm
http://www.geocities.com/MotorCity/P...ct/Engine.html
http://www.mad-mechanic.com/toyota/t...tml#obtaincode
http://www.freewebs.com/th3duke/22RE-ECU.mht
http://www.troublecodes.net/Toyota
http://www.autoshop101.com/forms/h27.pdf
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
http://forum.ih8mud.com/79-95-toyota...ror-codes.html
http://www.showmesome.info/hilux/inf...E/Page0096.htm
http://www.efisakh.narod.ru/at_toyota.htm (auto tranny codes)
http://www.usatransdoctor.com/foreigntoyota.htm
http://www.obd-codes.com/forums/viewforum.php?f=3
Pulling the ECU (EFI computer) codes is the first thing I do to diagnosis a problem thereafter I reset the ECU to see if the same problems show up and if so I then take voltage measurements at each ECU wire both with the engine running and not and compare with the factory service manual, I also close the ignition switch after a cold engine and also after a warm engine and compare the resistance values with the factory service manual.
This technique will completely isolate your problem without having to do trial and error and it is the technique I use when repairing tv's, vcr's, home/car audio.
Sidney
Sidney is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 05:00 PM #4
Edweller Edweller is offline
Edweller is on a distinguished road
Toyota 4Runner Forum - Largest 4Runner Forum - Powered by vBulletin
Car Maintenance, Repairs, & How-Tos
Sidney
amazing, thank you.
Edweller is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 07:17 AM #5
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Old thread but, worth the bump for sure. Some quality links there!
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Daystar, Spidertraxx, Removed the running boards Bigrupp 4th Gen T4Rs 9 09-27-2010 11:27 PM
Running Boards or not? Zinarac Classic T4Rs 20 07-09-2007 02:20 AM
WANTED: Running board brackets jamlim Classifieds - buy & sell (no commercial ads please) 0 08-27-2006 03:18 PM
running rich imboredeveryday 3rd gen T4Rs 5 08-17-2006 11:32 PM
Running Board lights smokey7722 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 07-09-2006 02:11 PM
