09-13-2008, 03:19 PM
Havin some engine problems. . .
Ok, I have a 3.0L V6 with 5 speed. When I start the truck after its been sitting for awhile it won't rev above 1000 RPM. I put it in gear and let out on the clutch and it barely moves. Then after a minute or two of this, its fine. Any ideas?
2009 Shadow Mica Trail Edition - 2" Dobinson lift, 285/75r16 Cooper ST MAXX, gunmetal FJ Cruiser 16" TRD wheels, 1.25" Spidertrax spacers, Powerstop rotors and pads, Rola roof rack with 4xInnovations low pro mounts and LED's front and rear, NAPA awning, Rago ditch light brackets with Caliraised side shooter led pods, Caliraisedled 2012-15 Tacoma fog light mounts with amber led pods
09-20-2008, 06:55 PM
Sounds similiar to my problem after a heavy rain. I have an automatic, but it won't rev and won't shift until it warms up and dries out, then it's fine. Try spraying the inside of the distributor and cap and wires with WD40. If that helps, it is probably condensation or moisture and possibly a bad wire or hairline crack in the cap.
09-20-2008, 07:26 PM
Actually I'm about to change the cap, rotor, wires, plugs, oil, oil filter, fuel filter, and possible tranny fluid. So we'll see
09-27-2008, 06:41 PM
How did it go? I still can't get a handle on it. All the wires, cap an rotor are new now and it still runs like crap after heavy rain. Hope you had better luck.
09-29-2008, 08:37 PM
We haven't had a real heavy rain since. It still idles weird and my oil pressure seems low after lots of driving
10-03-2008, 11:17 AM
From what I have read, the low oil pressure is pretty normal for this engine. Mine is low after the oil heats up too.
10-03-2008, 03:04 PM
Check your coil wire and the ignition wires leading to the coil. Moisture in the wiring harness and connectors can cause the problems you are describing.
10-03-2008, 05:45 PM
Re: Havin some engine problems. . .
Try cleaning the MAF sensor.
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
10-04-2008, 04:20 PM
What is the MAF sensor and where is it located?
10-04-2008, 06:58 PM
Re: Re: Havin some engine problems. . .
Mass air flow sensor. It may be called something different on the early engines but it is doing the same job. It's located in the throttle body after the air filter and before the throttle butterfly. It will be the only thing with wires running to it in that area.
Larry
10-14-2008, 09:34 PM
MAF cleaning instructions:
http://www.4x4wire.com/toyota/mainte...tenancep5.html
There's a lot of other great info here.
'94 V6 at, stock, 146K, Surco rack - bought 10/08
'89 V6 5spd, Add-a-leaf in back, 32 BFG ATs, 248K, permanent check engine light, rod knock - Sold 11/08!
'84 Red/White, 31 BFG ATs, Rebuilt 22R - Stolen/Recovered/Sold at 196K Jan/00
10-18-2008, 12:15 PM
Thanks CD, excellent site.
