I'll be acquiring an '88 4Runner relatively soon. But it has brake problems. The pedal is real mushy and doesn't really stop with much power, it stops, it just takes a while. Any suggestions where to start or what the problem may be?
Push down hard on the brake pedal. If the brake pedal goes slowly to the floor, it is probably the master cylinder.
If the brake pedal gets better as you pump it, it is most likely air or water in the brake lines or wheel cylinders.
Replacing a master cylinder is not a tough job at all. You don't even have to crawl under the vehicle until you bleed the brakes. A rebuilt master cylinder should be less than $100.USD.
i blame hudson. nice 1st post lol. i couldnt figure out my brake problems untill i finaly noticed my rear brake adjester was backing off. clicker would allow it to spin backwords. (kinda like my spelling)
