Originally posted by the_dingman
Often times people will recommend replacing a water pump when doing a timing chain... Is that something I should look at?
Unfortunately I am not an expert on these engines so cannot say with absoute certainty. If it were me then I would probably replace the water pump. The oil pump also comes to mind but I don't think they tend to go bad like water pumps.
What I can advise, from everything that I have heard, is that you need to stay Toyota OEM with the water pump. Do not go with a local parts house brand.
