The howling is probably the drive-shaft and front differential spinning. Those hubs are pretty simple, and it's likely stuck engaged, even though it's only half way. The problem is that it puts a lot of extra pressure on the small part of the sprockets that are engaged. I would remove the hub and inspect it. They're really simple to remove and work on.
1986 4Runner Deluxe, 5SPD, R.I.P. @ 182k Miles, July, 2001 - November, 2004.
1987 4Runner SR5, 5SPD, 236k. July 2007-Present
