Old 08-30-2009, 04:54 PM #1
ssccchef ssccchef is offline
ssccchef is on a distinguished road
I'm worried this mechanic is trying to screw me - '95 4R engine ticking
My check engine light had been on, and when I drive my rig, it makes a ticking noise up around 3,000 rpm.
I took it to a local mechanic (I just moved to this town, so I don't have a guy).
He told me the check engine light was due to loose electrical connections, which he fixed.
He told me the ticking was indicative of an engine bearing that was getting ready to go.
He says he'll only do a complete engine rebuild, or swap in another used engine, charging around $4,000 or around $2,500 respectively.
I'm gonna go get another opinion, but I'm a college student, so I can't really afford to keep paying $80 diagnostic fees.
Does this pass everybody's sniff test? Is this guy trying to screw me? I need help and advice, please.
Thank you guys in advance.
ssccchef is offline   Reply With QuoteReply With Quote
Old 08-30-2009, 05:02 PM #2
the_dingman's Avatar
the_dingman the_dingman is offline
the_dingman is on a distinguished road
it could be a bad bearing, or it could be just something loose in a 14 year old engine.
1986 4Runner Deluxe, 5SPD, R.I.P. @ 182k Miles, July, 2001 - November, 2004.
1987 4Runner SR5, 5SPD, 236k. July 2007-Present
the_dingman is offline   Reply With QuoteReply With Quote
Old 08-31-2009, 12:47 PM #3
ovrrdrive's Avatar
ovrrdrive ovrrdrive is offline
ovrrdrive is on a distinguished road
ovrrdrive's Avatar
Get a second opinion but don't bother for a third. If they agree you have your answer most likely.
If it's just ticking it's not really a time bomb yet. I'd run it until it explodes and then get it swapped out if it were me.
2003 Silver/Gray SE5 V8 T4R
1995 4x4 Xcab Truck 8.5" lift, 36x13.5 Iroks on M/T Classic Locks, 5.29's, Lockright locker, OBA and a Train Horn
ovrrdrive is offline   Reply With QuoteReply With Quote
Old 08-31-2009, 01:08 PM #4
turboSR5's Avatar
turboSR5 turboSR5 is offline
Real Name: Todd
turboSR5 is on a distinguished road
turboSR5's Avatar
Real Name: Todd
Is it just me or...
...is $2,500 just a little high to pay for a used engine install?
1986 4runner 22RTE Turbo SR5 - R.I.P.
1986 Extra-Cab Pickup DLX - Sold
1987 4runner 22re SR5
1984 2wd Exrta Cab
1982 BJ60
turboSR5 is offline   Reply With QuoteReply With Quote
Old 08-31-2009, 04:16 PM #5
Justinlhc Justinlhc is offline
Justinlhc is an unknown quantity at this point
Most 3vze engines I've heard are noisey. Min has been "ticking" for several thousand miles. Could need the lifters adjusted or it could just be the injectors. I've never heard a 3.0 that didn't have a tick. I wouldn't spend that kinda money fixing a problem that isn't going to leave you stranded.
1993 4Runner SR5 with the usual stuff. Locked rear with 32x11.50 BFG KM's.
Justinlhc is offline   Reply With QuoteReply With Quote
Old 08-31-2009, 05:54 PM #6
ryansmagic ryansmagic is offline
ryansmagic is on a distinguished road
Try a little thicker oil for a few miles can help too. 5w30, go to 10w30, that will sometimes take care of the problem
ryansmagic is offline   Reply With QuoteReply With Quote
Old 08-31-2009, 06:53 PM #7
SHRIKE SHRIKE is offline
SHRIKE is on a distinguished road
You need to establish if the ticking is timed w/the crank timing or cam timing... If it is the crank timing then try to determine wich rod it is... Then pull the plug wire off that cylinder while it's running.... If the ticking stops, it's probably a bearing... If it's cam timing then it could just be a loose rocker??... Go to sears and get a stethoscope, I think they are six bucks... You can always do as suggested and run straight 50 in it until it grenades... It could run another 20K miles ticking... If it's hurt now then who cares??...
SHRIKE is offline   Reply With QuoteReply With Quote
Old 09-01-2009, 09:46 PM #8
Savage's Avatar
Savage Savage is offline
Savage is an unknown quantity at this point
Savage's Avatar
sounds like top end to me...valves, lifters etc..not a huge deal and if you're even close to doing what this mechanic proposes I too would run the piss out of it till it goes...change the oil to heavier grade and change it regularly. Other than the ticking it runs good? Has plenty of torque and everything?
Savage is offline   Reply With QuoteReply With Quote
Old 09-02-2009, 12:19 AM #9
Many opinions, the most common is not to worry about it. Older engines make noises when they're running perfectly that would indicate fatal problems on newer engines, as some stuff from the older days is just noisier. The 22RE (the 4cyl engine) is well known for a very loud tick, which sounds like a big problem, but is really just the fuel injectors working.
Drive it until it starts having more problems. A new engine will cost the same weather the old one is making noise or if it shoots a rod out the side. Even if you have to eventually spend the money to replace it, why not get the most out of this one?
Old 09-02-2009, 07:46 AM #10
Get your new 22RE from Putney's....
Old 09-25-2009, 01:15 AM #11
SASK T4R SASK T4R is offline
Registered User
SASK T4R is an unknown quantity at this point
Registered User
Talking
tell that mechanic to go fist himself. mine does the same thing,my mechanic says its perfectly normal in the older yotas,he told me even his wifes fj does it(not near as loud of course) so dont sweat it
SASK T4R is offline   Reply With QuoteReply With Quote
Old 09-28-2009, 09:30 AM #12
fishrod's Avatar
fishrod fishrod is offline
fishrod is on a distinguished road
fishrod's Avatar
Haha, I just posted on another "ticking" issue about this, so im gonna suggest the same thing.
See if you can find the Fuel Pressure Regulator. Sits on top of the engine, roundish kinda thing. Get someone to rev the engine up to 2000 revs and touch it with your hand. If its the FPR you can feel the ticking in your finger.
No need to replace it, just leave it tick away to itself!
fishrod is offline   Reply With QuoteReply With Quote
Old 10-20-2009, 09:18 PM #13
03vrod's Avatar
03vrod 03vrod is offline
03vrod is on a distinguished road
03vrod's Avatar
which engine do you have?
03vrod is offline   Reply With QuoteReply With Quote
Old 10-20-2009, 09:55 PM #14
fishrod's Avatar
fishrod's Avatar
v6 3vze
Old 11-02-2009, 12:03 PM #15
FISH HUNTER's Avatar
FISH HUNTER FISH HUNTER is offline
FISH HUNTER is on a distinguished road
Is this high ticking noise (like injectors) or a lower pitched ticking noise like a valve or bearing noise?
93 4X4 Auto 88K miles 31x10.5, Downey Off Rd Ft Tor Brs and H&R rr lift spring,
FISH HUNTER is offline   Reply With QuoteReply With Quote
