Originally Posted by Barnaby
I would try the easy stuff first, maybe a basic tuneup followed by maybe a fuel filter. If that does nothing, then I would see if a tank of higher grade fuel takes care of it.
First of all, thank you for your reply.
I have recently changed the plugs, air filter, ran a can of seafoam through it (which DID...INSTANTLY eliminate any hesitation and sputtering...amazing stuff)....When I DO run the high grade (93 octane) fuel...it HELPS...but does not completely eliminate the problem. Thinking about trying new plug wires next, then maybe new rotor and cap.
Thanks again!
