same here....code 52 angst in CO
Hey pioneer,
Im having the same problem, replaced KS, wire to harness, timing belt, water pump, tension pulley/spring, intake and plenum gaskets, distributor(used), distributor cap and rotor, plugs & wires, TPS(used), and MAF(used), checked for vac leaks, kicked cursed and begged but nothing has removed my code 52. If you figure it out, let me know.
As for the oil, I had a similar puddle(mixed oil and anti-freeze), and after sucking it out with a vac I found fine dirt and debris in the bottom. I figure it comes from spilling oil from the filler cap, as it has nowhere to drain to.
