12-08-2009, 03:45 PM
Rear/tailgate window motor
Does anyone know where I can get a rear/tailgate window motor for a 1986 4-Runner?
Also does anyone know if the front passenger or driver side door window motor can be used to replace the tailgate window motor. I know sometimes identical parts are given different part numbers because the parts are installed in other locations on the vehicle.
Thanks KK's 86
86 4-Runner, 5 speed manual, 22R,
864runr
12-08-2009, 06:58 PM
Try Ebay there is always a few on there for sale....Good luck
I am the PuddyDad, Creator of things for the S2000, Part provider to 4 Maltese dogs we lovingly refer to as Puddys. Puddy is a mix of two words, puppy and buddy. Small dogs like Maltese are little like a puppy and all dogs are your best buddy. Put the two together and you have a Puddy.
Rest in peace Cosmo The Wonder Puddy, we love and miss you very much
http://www.s2ki.com/forums/index.php...owtopic=825385
12-09-2009, 10:57 PM
i don't think the rear would be the same as the front(s), tailgate window is much heavier.
i've got one that i'm not using. was going to use it for my back window (just finished converting to pick-up), but just a thought. do you just need the motor itself?let me know if you can't find one easily!
12-11-2009, 06:49 PM
Thanks for the reply.
I tried ebay but couldn't find one. There are plenty of door motors but no rear window/tailgate motors. How hard would it be to rebuild one or do you think it would be possible.
864runr
12-11-2009, 07:00 PM
How much you want for the motor and does it still seem to have plenty of power? My window motor is the original 1986 part. It got slower and slower until I finally had to help it close. I also looking for weather stripping and a good window channel for the rear window. My channel is pretty rusted.
I'm sure your right about a front window motor not being strong enough to work the heavier back window but it seemed strange for them to have manufactured two different window motor. I know many companies make one part becasue it's cheaper to manufacuture one single part than two different ones. The motors look identical. If your willing to sell the motor by it's self that would be great. If you would rather sell the regulator and motor I'm still interested.
Thanks
1986 4-Runner R22 270 K Manual Transmission.
864runr
12-11-2009, 10:15 PM
Toyota has a tendancy to re-use parts across different models and years. You'll find that the rear drum brakes on your '86 are nearly identical to current Tacomas.
The front window motor is likely used on other models, and was probably around for some time before the 4Runners. The rear window will require a larger motor, and it was likely built for this window, and has probably been used in other applications since.
1986 4Runner Deluxe, 5SPD, R.I.P. @ 182k Miles, July, 2001 - November, 2004.
1987 4Runner SR5, 5SPD, 236k. July 2007-Present
12-12-2009, 10:46 PM
Has anyone tried a 2nd gen motor.I used the cables from one because mine were sticking and toyota wanted 90 for new ones.
do you know if its the motor thats bad? have you tried applying just 12 volts to the motor to see if it works. if it does, than you issue could be the computer box for the rear window that is bad.
motors can be found in junk yards, online auto part stores, and your local toyota dealer
12-13-2009, 07:32 PM
the spare motor i have is from an '87, it still works, i've got the window sliders from inside the tailgate, just let me know if you want them.
12-13-2009, 11:58 PM
I have a working motor, currently attached to the regulator. It's the original from my truck. The motor's good, but the regulator rusted out. The motor is likely rusted to the regulator, but I may be able to get it off...
12-15-2009, 08:20 PM
How much do you want for the rear window assembly? I am in Vancouver, BC.
By the way the 90's Camry Power Window Motor is the same. Those are easier to find in the Junkyards.
12-21-2009, 12:33 PM
Rear window motor
Thanks for the info. I looked on ebay and found several. I got one on order but am looking to pick up another one as a spare.
Thanks again.
864runr
12-21-2009, 12:37 PM
Rear window motor
Thanks for the info on the rear/front window motors. You saved me some money. I sure would like to get the motor if possible. Still got it?
864runr
12-21-2009, 12:39 PM
Rear window motor
Thank you for the help. The motor is different as you said. I picked up one on ebay but I'm looking to find another one for a spare.
Thanks again
864runr
12-21-2009, 12:42 PM
Rear window motor
I was told the 2gen would work.
864runr
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
