Old 02-27-2016, 02:32 AM #16
a red 4runner's Avatar
a red 4runner a red 4runner is offline
a red 4runner is on a distinguished road
I've been reading up on how GL-5 rated gear oil has a higher sulfur content and can corrode the synchros even though the manual says you can use GL-4 or GL-5. A lot of people with shifting issues have said that Redline MT-90 or Royal Purple are good GL-4 oils that are made for helping your synchros grip.
Something else you can try is OVERFILLING your transmission. But only slightly, like a 1/4 quart (1cup). I read about it here: CURE NOTCHY SHIFTING! 3rd gen and taco - Page 2 - YotaTech Forums
My R150F transmission had pretty grindy shifting but I tried this just for shits and giggles and, to my amazement, overfilling it .25 quarts actually made a big difference! It still grinds, but noticeably less.
I recently got some of that Redline MT-90 gear oil that I'll be putting in soon. I'll let you guys know what happens.
a red 4runner is offline   Reply With QuoteReply With Quote
Old 02-28-2016, 01:38 PM #17
Bad_Vision's Avatar
Bad_Vision Bad_Vision is offline
Bad_Vision is on a distinguished road
Bad_Vision's Avatar
Beat solution I have found is a 60/40 60% gl5 and 40% ATF 3
Cleans the fluid and parts also makes the fluid thinner so smoother shifting. Never had a tranny fail using this. And always nice clean fluid when I change it out!
Classic's Section Moderator
http://www.4crawler.com/4x4/CheapTricks/index.shtml
My 1985 TDI swapped 4Runner http://www.toyota-4runner.org/classi...-tdi-swap.html
Bad_Vision is offline   Reply With QuoteReply With Quote
Old 03-04-2016, 12:51 PM #18
Tpress Tpress is offline
Tpress is on a distinguished road
same
I had that problem. I usually come to a COMPLETE stop then shift into reverse as i am letting the clutch out a little. this works most of the time. once i get it in i slam the clutch pedal down. it works but should be checked out.
Tpress is offline   Reply With QuoteReply With Quote
Old 09-24-2016, 07:37 PM #19
Originally Posted by santanvalleydirt View Post
Mine grinds randomly when going into reverse. Even before I've started driving it will do it.
Remember: Even if your wheels aren't turning, if your engine is turning then your tranny is turning.
Originally Posted by nathan25 View Post
Try giving it gas when going into reverse
That will only make a greater difference in speed between the input shaft and the reverse gear.
Old 10-21-2016, 10:52 AM #20
kenwood1986 kenwood1986 is offline
Real Name: Tommy
kenwood1986 is on a distinguished road
Real Name: Tommy
I agree with the above , reverse does not have a syncro so you need to be at a complete stop . Even the owner's manual says if you have a hard time going into reverse , put it in neutral , take your foot off the clutch , then push it back in and go back to reverse , that's pretty much just double clutching it . Mine likes to give me problems every now and then too , I more or less just ignore it , just chock it up to there being no syncro for reverse .
1995 SR5 V6 4x4 5-SPEED
kenwood1986 is offline   Reply With QuoteReply With Quote
Old 08-17-2020, 05:48 PM #21
4x4withcheese 4x4withcheese is offline
4x4withcheese is on a distinguished road
95 Manual trans fill plug
Hey I know this is unrelated to this specific thread but the site won't let me post yet because I don't have enough responses posted so - I haven't been able to check the transmission fluid on my 1995 4x4 manual 4runner with the 3L V6 because I don't know where the fill plug is or what it looks like. I haven't found anything on the internet about these transmissions; can anything tell me what this plug looks like and where it's located?
4x4withcheese is offline   Reply With QuoteReply With Quote
Old 08-17-2020, 06:56 PM #22
GG5thGen's Avatar
GG5thGen GG5thGen is offline
GG5thGen will become famous soon enough
GG5thGen's Avatar
Originally Posted by Bad_Vision View Post
The problem is reverse does not have a synchro. The simple solution is to put the vehicle in fifth using the Synchro then reverse will go in like butter.
If you still get grinding on the fifth gear your clutch is not engaging correctly or your synchros are shot
I agree. I used to have an Alfa Romeo that would grind when I put it in reverse. I always slippped into 5th first and then put it in reverse. Smooth as a school marm's thigh.
GG5thGen is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 10:11 AM #23
WPG93's Avatar
WPG93 WPG93 is offline
Real Name: Paul
WPG93 is on a distinguished road
WPG93's Avatar
Real Name: Paul
24mm on the driver's side. Not the hex key on the passenger side.
You likely have the R150F transmission unless someone changed it on you.
Toyota truck transmission identification – Core Shifters
Grinding into reverse-avj1q8p-jpg
WPG93 is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 08:01 PM #24
ironbender3 ironbender3 is offline
ironbender3 is on a distinguished road
Hi also new member working on minimum post count. Got a '88 3.0L V6 (3VZE) and I honestly just have a really loud pinging/knocking when I'm in neutral. Recently refilled/replaced gear oil in transmission, transfer case, and rear diff and it has made no difference. Am I worrying over nothing or is this a serious issue?
Don't know if this needs to be said but it is a manual transmission.
ironbender3 is offline   Reply With QuoteReply With Quote
Old 01-22-2021, 11:05 AM #25
alabamatoy alabamatoy is offline
alabamatoy is on a distinguished road
grinding into reverse can also be due to an incorrectly adjusted clutch, ie its not disengaging all the way. Sometimes bleeding the system can solve that.
86 4Runner, original owner
5VZ transplant, solid axle etc...
99 4Runner 5spd, original owner
Still going strong
alabamatoy is offline   Reply With QuoteReply With Quote
'91 grinding sound bueller Classic T4Rs 16 01-17-2012 01:07 PM
Reverse Sensing Wire Goatdog Engines / Suspension / Wheels / Tires / Audio / Accessories 3 04-27-2010 07:51 PM
front end 4x4 noise in reverse???? 08medic4x4 Classic T4Rs 2 03-08-2010 12:43 AM
'91 grinding issue bueller Problems & Warranty Issues 0 02-15-2010 03:50 PM
2003 V8 DAC & Reverse to Drive Problems!!! 4RunnerLaker Problems & Warranty Issues 10 08-30-2004 06:15 PM
