10-30-2004, 03:27 PM
Back Window key
OK, The back window goes up and down with the switch up front...but the back key does nothing.
Where do i start?
I tried pulling the lock cyl out and hooked it up to an ohm meter to check for continuity...doesn't look like theres any juice flowing through the thing in any key position.
How do i go about replacing it with the same key? Or does any one have any better solutions to this one?
Thanx in advance
10-30-2004, 06:29 PM
what year?
Tiny House Basics
www.TinyHouseBasics.com
10-30-2004, 08:48 PM
It's a 1990.
One update...the key works to send the window up..but not down
10-30-2004, 10:34 PM
Weird mines does the same thing. I'll be waiting for the answer to this problem. Mines a 1990 2dr 4runner. Maybe its common for this year??
11-02-2004, 12:04 AM
Interesting: My '90 works fine from the key switch, tho I have to wiggle it to get the key to work to run the window up. The inside switch does not roll it down at all, and only rolls it up intermittantly.
I cleaned the inside switch, the lock-out switch and the motor contacts in the tailgate before it worked at all tho!
1990 V6/5speed 4Runner
K&N filter
Pioneer tunes
Lund visor
T4R.ORG sticker
http://vwcabrio.org
11-02-2004, 01:38 AM
I was in the back door trying to get the rear defrost working. (which by the way takes forever to heat up) and I used white grease on basically all moving parts. WHAT a difference...much faster and smoother now. If your window is moving slowly I would definitley recomend this simple, cheap and fast although I'm sure temporary solution.
But still no down on the rear key switch....anybody know how to fix this?
11-03-2004, 10:30 AM
I have a 1994 and my key you have to wiggle it sometimes to get it to work, but most of the time it works great. My switch on the inside used to work great, then one day it stopped rolling the window down. It has no problem rolling it up, but it wont roll down. Also, is it like a normal thing for the rear defroster to stop working? I opened my tailgate and the actual wires are disconected from the window.
1994 4 Runner 4X4
5 Speed Manual
Leather, Sunroof, All Power Options
31X10.5R15 Bridgestone Dueler Revos
15 Inch Ion Rims
2 Rockford Fosgate Amps 500 watts and 700 watts
1 10" Rockford Fosgate Sub
Silverstar lights
Fully Loaded
12-31-2010, 01:11 PM
Same back window problem
Hey, i just joined the site and was reading about the back window problems with my 94 4runner. I am having the same problem with mine accept the switch on the tailgate doesn't do anything, i have tried wiggling with nothing. Defrost doesn't work either. i am intrested in finding out what i can do as cost efficent as possible.
12-31-2010, 04:07 PM
Mine never worked for going up, but works for going down. Haven't had time to figure that one out yet.
1991 4Runner SR5 - 22R-E - G58 - daily/mild trails
1984 Pickup SR5 - 22R - ??? - work to do
Goners: '91 V6 4R SR5 x2, '93 V6 4R SR5, '84 4R SR5
12-31-2010, 08:20 PM
Moderator
Real Name: The Chosen One
Moderator
There are several possibilities.
Common ones are dirty switch contacts/bad switch, or a bad relay in the control module.
'89 4Runner SR5 - stock
01-02-2011, 01:07 AM
my key doesn't turn at all, any ideas on how to free it up?
87 4Runner - 22RE(Swapped at 269k with a 130k from a celica), Tranny(269k rebuilt)
Two 10" T3 400RMSx2 Subwoofers, 4" and 5.5" Amped Auditor speakers pushing about 75RMSx4
01-11-2011, 08:30 PM
Check out the following link. It MAY help you with your problem.
4Runner Rear Window Cheap Tricks
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
